Visitor billhodgins
xps_intc platgen parameter override failure
I have a simple, working, dual microblaze system without an xps_intc.  When I add the xps_intc core to microblaze_1, TCL procedures fail parameter overrides on the xps_intc core.
eg. error computing override value for C_NUM_INTR_INPUTS using tcl
Manually overriding the parmeters in the .mhs file results in the same errors.
Any ideas, platgen log follows...
At Local date and time: Thu Jan 15 12:01:34 2009
 make -f system.make bits started...
Creating system netlist for hardware specification..
platgen -p xc3s2000fg456-5 -lang vhdl   system.mhs
Release Xilinx EDK 10.1.03 - platgen EDK_K_SP3.6
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
Command Line: platgen -p xc3s2000fg456-5 -lang vhdl system.mhs
Parse system.mhs ...
Read MPD definitions ...
Overriding IP level properties ...
INFO:MDT - IPNAME:microblaze_0 INSTANCE:microblaze -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v7_10_d\data\mic
   roblaze_v2_1_0.mpd line 164 - tcl is overriding PARAMETER C_ADDR_TAG_BITS
   value to 0
   roblaze_v2_1_0.mpd line 173 - tcl is overriding PARAMETER C_DCACHE_ADDR_TAG
   value to 0
INFO:MDT - IPNAME:microblaze_1 INSTANCE:microblaze -
   value to 0
   value to 0
Performing IP level DRCs on properties...
Running DRC Tcl procedures for OPTION IPLEVEL_DRC_PROC...
Address Map for Processor microblaze_0
  (0000000000-0x00003fff) dlmb_cntlr_0 dlmb_0
  (0000000000-0x00003fff) ilmb_cntlr_0 ilmb_0
  (0x81400000-0x8140ffff) interrupt_out_0 mb_plb_0
  (0x81420000-0x8142ffff) led_indicators_0 mb_plb_0
  (0x83418000-0x8341bfff) xps_bram_if_cntlr_0 mb_plb_0
  (0x8341c000-0x8341ffff) xps_bram_if_cntlr_IP_CORE_0 mb_plb_0
Address Map for Processor microblaze_1
  (0000000000-0x00007fff) dlmb_cntlr_1 dlmb_1
  (0000000000-0x00007fff) ilmb_cntlr_1 ilmb_1
  (0x81400000-0x8140ffff) rx_hi_lo_1 mb_plb_1
  (0x81420000-0x8142ffff) tx_level_1 mb_plb_1
  (0x81440000-0x8144ffff) led_indicators_1 mb_plb_1
  (0x81800000-0x8180ffff) xps_intc_1 mb_plb_1
  (0x83400000-0x8340ffff) xps_spi_1 mb_plb_1
  (0x83418000-0x8341bfff) xps_bram_if_cntlr_1 mb_plb_1
  (0x84000000-0x8400ffff) usb_1 mb_plb_1
  (0x84400000-0x8440ffff) debug_module_shared mb_plb_1
Check platform address map ...
Computing clock values...
Overriding system level properties ...
   roblaze_v2_1_0.mpd line 125 - tcl is overriding PARAMETER C_D_PLB value to 1
   roblaze_v2_1_0.mpd line 126 - tcl is overriding PARAMETER C_D_OPB value to 0
   roblaze_v2_1_0.mpd line 128 - tcl is overriding PARAMETER C_I_PLB value to 1
   roblaze_v2_1_0.mpd line 129 - tcl is overriding PARAMETER C_I_OPB value to 0
   roblaze_v2_1_0.mpd line 183 - tcl is overriding PARAMETER C_USE_INTERRUPT
   value to 1
   roblaze_v2_1_0.mpd line 184 - tcl is overriding PARAMETER C_USE_EXT_BRK value
   to 1
   roblaze_v2_1_0.mpd line 185 - tcl is overriding PARAMETER C_USE_EXT_NM_BRK
   value to 1
INFO:MDT - IPNAME:mb_plb_0 INSTANCE:plb_v46 -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\plb_v46_v1_03_a\data\plb_v4
   6_v2_1_0.mpd line 34 - tool is overriding PARAMETER C_PLBV46_NUM_MASTERS
   value to 2
   6_v2_1_0.mpd line 35 - tool is overriding PARAMETER C_PLBV46_NUM_SLAVES value
   to 4
   6_v2_1_0.mpd line 36 - tool is overriding PARAMETER C_PLBV46_MID_WIDTH value
   to 1
   6_v2_1_0.mpd line 38 - tool is overriding PARAMETER C_PLBV46_DWIDTH value to
   32
INFO:MDT - IPNAME:ilmb_0 INSTANCE:lmb_v10 -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\lmb_v10_v1_00_a\data\lmb_v1
   0_v2_1_0.mpd line 37 - tool is overriding PARAMETER C_LMB_NUM_SLAVES value to
   1
INFO:MDT - IPNAME:dlmb_0 INSTANCE:lmb_v10 -
   1
INFO:MDT - IPNAME:dlmb_cntlr_0 INSTANCE:lmb_bram_if_cntlr -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\lmb_bram_if_cntlr_v2_10_a\d
   ata\lmb_bram_if_cntlr_v2_1_0.mpd line 43 - tcl is overriding PARAMETER C_MASK
   value to 0x80000000
INFO:MDT - IPNAME:ilmb_cntlr_0 INSTANCE:lmb_bram_if_cntlr -
   value to 0x80000000
INFO:MDT - IPNAME:lmb_bram_0 INSTANCE:bram_block -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\bram_block_v1_00_a\data\bra
   m_block_v2_1_0.mpd line 36 - tool is overriding PARAMETER C_MEMSIZE value to
   0x4000
INFO:MDT - IPNAME:interrupt_out_0 INSTANCE:xps_gpio -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\xps_gpio_v1_00_a\data\xps_g
   pio_v2_1_0.mpd line 41 - tool is overriding PARAMETER C_SPLB_NUM_MASTERS
   value to 2
   value to 1
   to 1
   value to 1
INFO:MDT - IPNAME:mb_plb_1 INSTANCE:plb_v46 -
   value to 2
   to 1
   32
INFO:MDT - IPNAME:ilmb_1 INSTANCE:lmb_v10 -
   1
INFO:MDT - IPNAME:dlmb_1 INSTANCE:lmb_v10 -
   1
INFO:MDT - IPNAME:dlmb_cntlr_1 INSTANCE:lmb_bram_if_cntlr -
   value to 0x80000000
INFO:MDT - IPNAME:ilmb_cntlr_1 INSTANCE:lmb_bram_if_cntlr -
   value to 0x80000000
INFO:MDT - IPNAME:lmb_bram_1 INSTANCE:bram_block -
   0x8000
INFO:MDT - IPNAME:led_indicators_1 INSTANCE:xps_gpio -
   value to 2
INFO:MDT - IPNAME:led_indicators_0 INSTANCE:xps_gpio -
   value to 2
INFO:MDT - IPNAME:usb_1 INSTANCE:xps_uartlite -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\xps_uartlite_v1_00_a\data\x
   ps_uartlite_v2_1_0.mpd line 45 - tool is overriding PARAMETER
   C_SPLB_NUM_MASTERS value to 2
INFO:MDT - IPNAME:xps_spi_1 INSTANCE:xps_spi -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\xps_spi_v2_00_b\data\xps_sp
   i_v2_1_0.mpd line 44 - tool is overriding PARAMETER C_SPLB_NUM_MASTERS value
   to 2
INFO:MDT - IPNAME:rx_hi_lo_1 INSTANCE:xps_gpio -
   value to 2
INFO:MDT - IPNAME:tx_level_1 INSTANCE:xps_gpio -
   value to 2
INFO:MDT - IPNAME:debug_module_shared INSTANCE:mdm -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\mdm_v1_00_d\data\mdm_v2_1_0
   .mpd line 55 - tool is overriding PARAMETER C_SPLB_MID_WIDTH value to 1
   .mpd line 56 - tool is overriding PARAMETER C_SPLB_NUM_MASTERS value to 2
INFO:MDT - IPNAME:bram_block_shared INSTANCE:bram_block -
   0x4000
INFO:MDT - IPNAME:xps_intc_1 INSTANCE:xps_intc -
   C:\Xilinx\10.1\EDK\hw\XilinxProcessorIPLib\pcores\xps_intc_v1_00_a\data\xps_i
   ntc_v2_1_0.mpd line 44 - tool is overriding PARAMETER C_SPLB_NUM_MASTERS
   value to 2
ERROR:MDT - C_NUM_INTR_INPUTS (xps_intc) - can't use non-numeric string as
   operand of "-"
       while executing
   "expr {abs($svec - $fvec) + 1}"
       (procedure "hw_intc_core_v1_00_c::update_num_intr_inputs" line 21)
       invoked from within
   "hw_intc_core_v1_00_c::update_num_intr_inputs "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_num_intr_inputs" line
   8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_num_intr_inputs 55821172"
ERROR:MDT - IPNAME:xps_intc INSTANCE:xps_intc_1 -
   ntc_v2_1_0.mpd line 48 - error computing override value for C_NUM_INTR_INPUTS
   using tcl
ERROR:MDT - C_KIND_OF_INTR (xps_intc) - can't use non-numeric string as operand
   of "-"
       while executing
       (procedure "hw_intc_core_v1_00_c::update_kind_of_intr" line 32)
       invoked from within
   "hw_intc_core_v1_00_c::update_kind_of_intr "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_intr" line 8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_intr 55822824"
make: *** [implementation/system.bmm] Error 2
   ntc_v2_1_0.mpd line 49 - error computing override value for C_KIND_OF_INTR
   using tcl
ERROR:MDT - C_KIND_OF_EDGE (xps_intc) - can't use non-numeric string as operand
   of "-"
       while executing
       (procedure "hw_intc_core_v1_00_c::update_kind_of_edge" line 55)
       invoked from within
   "hw_intc_core_v1_00_c::update_kind_of_edge "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_edge" line 8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_edge 55823048"
   ntc_v2_1_0.mpd line 50 - error computing override value for C_KIND_OF_EDGE
   using tcl
ERROR:MDT - C_KIND_OF_LVL (xps_intc) - can't use non-numeric string as operand
   of "-"
       while executing
       (procedure "hw_intc_core_v1_00_c::update_kind_of_lvl" line 55)
       invoked from within
   "hw_intc_core_v1_00_c::update_kind_of_lvl "Intr" $mhsinst"
       (procedure "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_lvl" line 8)
       invoked from within
   "::hw_xps_intc_v1_00_a::syslevel_update_kind_of_lvl 55824644"
   ntc_v2_1_0.mpd line 51 - error computing override value for C_KIND_OF_LVL
   using tcl
Running system level Update ...
Running UPDATE Tcl procedures for OPTION SYSLEVEL_UPDATE_PROC...
ERROR:MDT - platgen failed with errors!
Done!
Visitor lizli428
Re: xps_intc platgen parameter override failure
Did you find the cause of this? My log looks the same except I do not get any errors.
The problem for me I think is that the plb bus size is overridden causing my application not to work.
Visitor billhodgins
No resolution on this yet.  I will rebuild this project from scratch to figure it out.
