Observer pablo.leyva
xsdk batch import sources - link to files
Hi everyone,
I am trying to automatize the creation of several SDK projects through tcl scripting and xsdk batch mode but I am facing problems with the importsources command.
The command make a copy of the files in my project folder, but I am interested in a link to the file, not a copy (my files are under revision control system). I would like to know if there is way to do this. In the GUI is straight forward, so I assume that should be a way to accomplish the same thing through command line.
Re: xsdk batch import sources - link to files
Hi @pablo.leyva
I would say that there is no way to link files/folders into a project using the XSDK commands. However your use case should be covered with the importprojects command. I mean add the cproject file also in the revision control system and being sure that all the path in the project uses relative path to the project location.
Ibai
Ibai
Scholar pratham
@pablo.leyva Check for the command here #67
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1208-xsct-reference-guide.pdf
-Pratham
Hi @pablo.leyva
Ibai
Ibai
Hi!
Thanks for the hint, it is doing the trick. It would be nice to be able to do it through TCL, but now it's up and running.
Pablo
Visitor monakov
Hi Pablo!
But importprojects also copies the project inside workspace. That's why I'm unable to get out-of-source build.
How does it work in your project?
After a bit of struggling with Xilinx SDK I've ended with this ugly script:
# Unset workspace path
sdk setws -switch $::env(TEMP)
# Import software project
exec $eclipse -vm $vm -nosplash                                    \
    -application org.eclipse.cdt.managedbuilder.core.headlessbuild \
    -import "file://$apppath" -data $wspath
# Set workspace path back
sdk setws -switch $wspath
# Build projects
sdk projects -build
$eclipse == $::env(RDI_APPROOT)/eclipse/$::env(RDI_PLATFORM)$::env(RDI_OPT_EXT)/eclipsec
$vm == $::env(RDI_JAVAROOT)/bin
$apppath == Full path to application project
$wspath == Full path to workspace directory
Note 'file://' prefix, script wont work without it. At least on Windows, where absolute paths begin with drive letter (D:/)
Yurii
Visitor joris
Dear Xilinx,
I don't see why this thread is marked as fixed.
The "proposed" solution is a hack around the Xilinx supported tcl files that manually starts eclipse and does some magic.
The real solution would be to add a parameter to the importprojects so that you can choose if you want to copy the projects into the workspace or not.
If you look around on the internet you see that quite some people have problems with the copy being made by the current implementation of importprojects;
http://www.edaboard.com/showthread.php?t=362643
https://forums.xilinx.com/t5/Vivado-TCL-Community/SDK-XCMX-command-Import-project-without-doing-a-copy-into/m-p/740402/highlight/true#M5358
I tried doing this, but I am unable to do regenbsp. The error it gives me is "couldn't open ".sdkproject": no such file or directory". Does anyone have this issue? or a workaround for this?
