10-17-2013 06:33 AM
ETH0 not working with 14.5 TRD
we've a custom board using as PHY the 'Vitesse 8211' and we problems to run eth0 with 14.5 TRD.
Here the linux boot with additional debug messages.
Starting kernel ... Booting Linux on physical CPU 0x0 Linux version 3.8.0-xilinx-trd (user@ubuntu) (gcc version 4.6.3 (Sourcery CodeBench Lite 2012.03-79) ) #42 SMP PREEMPT Thu Oct 17 14:22:38 CEST 2013 CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702 bootconsole [earlycon0] enabled cma: CMA: reserved 16 MiB at 11c00000 Memory policy: ECC disabled, Data cache writealloc PERCPU: Embedded 7 pages/cpu @c08a8000 s7616 r8192 d12864 u32768 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 76200 Kernel command line: console=tty0 console=ttyPS0,115200 root=/dev/ram rw ip=192.168.1.1:::255.255.255.0::eth0 earlyprintk mem=300M memmap=64M$0x1C000000 PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) __ex_table already sorted, skipping sort Memory: 300MB = 300MB total Memory: 263072k/263072k available, 44128k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) vmalloc : 0xd3000000 - 0xff000000 ( 704 MB) lowmem : 0xc0000000 - 0xd2c00000 ( 300 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc05b666c (5818 kB) .init : 0xc05b7000 - 0xc05e1dc0 ( 172 kB) .data : 0xc05e2000 - 0xc061e8e0 ( 243 kB) .bss : 0xc061e8e0 - 0xc0649658 ( 172 kB) Preemptible hierarchical RCU implementation. Dump stacks of tasks blocking RCU-preempt GP. RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. NR_IRQS:16 nr_irqs:16 16 xslcr mapped to d3002000 Zynq clock init timer #0 at d3004000, irq=43 sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms Console: colour dummy device 80x30 console [tty0] enabled Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 Setting up static identity map for 0x418620 - 0x418654 L310 cache controller enabled l2x0: 8 ways, CACHE_ID 0x000000c0, AUX_CTRL 0x72360000, Cache size: 524288 B CPU1: Booted secondary processor CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 Brought up 2 CPUs SMP: Total of 2 processors activated (2664.03 BogoMIPS). devtmpfs: initialized NET: Registered protocol family 16 DMA: preallocated 256 KiB pool for atomic coherent allocations xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xd300c000 hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. hw-breakpoint: maximum watchpoint size is 4 bytes. bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized PHY: phy_init() PHY: phy_driver_register() PHY: phy_init(); rc=0 usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb media: Linux media interface: v0.10 Linux video capture interface: v2.00 pps_core: LinuxPPS API ver. 1 registered pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> PTP clock support registered Switching to clocksource xttcps_clocksource NET: Registered protocol family 2 TCP established hash table entries: 4096 (order: 3, 32768 bytes) TCP bind hash table entries: 4096 (order: 3, 32768 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP: reno registered UDP hash table entries: 256 (order: 1, 8192 bytes) UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Trying to unpack rootfs image as initramfs... rootfs image is not initramfs (no cpio magic); looks like an initrd Freeing initrd memory: 18340K hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. msgmni has been set to 581 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) xuartps e0001000.uart: failed to get alias id, errno -19 e00ðconsole [ttyPS0] enabled, bootconsole disabled console [ttyPS0] enabled, bootconsole disabled xdevcfg f8007000.devcfg: ioremap f8007000 to d3060000 with size 100 brd: module loaded loop: module loaded PHY: phy_driver_register() PHY: phy_driver_register() ... PHY: phy_driver_register() PHY: phy_driver_register() ###Vitesse: vsc82xx_init() PHY: phy_driver_register() e1000e: Intel(R) PRO/1000 Network Driver - 2.1.4-k e1000e: Copyright(c) 1999 - 2012 Intel Corporation. Solarflare NET driver v3.2 xemacps e000b000.eth: ###HB board-type=BOARD_TYPE_ZYNQ libphy: XEMACPS mii bus: probed PHY: get_phy_device() PHY: get_phy_id(): addr=0x0,phy_id=0x0,is_c45=0 PHY: get_phy_id(): will call mdiobus_read(bus, addr, MII_PHYSID1) PHY: get_phy_id(): phy_reg=0xf PHY: get_phy_id(); phy_id=0xf0000, will call mdiobus_read(bus, addr, MII_PHYSID2) PHY: get_phy_id() END; phy_reg=0xc4b1 PHY: get_phy_device(), phy_id=0xfc4b1 PHY: get_phy_device(); will call phy_device_create() PHY: phy_device_create() PHY: phy_device_create(); addr=0 PHY: phy_device_create(); dev_set_name called PHY: phy_device_create(); dev=0xc4e18000 PHY: get_phy_device(); dev=0xc4e18000 PHY: phy_probe(); err=0 xemacps e000b000.eth: ###HB DRIVER_NAME=xemacps xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ehci-pci: EHCI PCI platform driver Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. mousedev: PS/2 mouse device common for all mice I2O subsystem v1.325 i2o: max drivers = 8 i2c /dev entries driver usbcore: registered new interface driver usbhid usbhid: USB HID core driver TCP: cubic registered NET: Registered protocol family 17 VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 Registering SWP/SWPB emulation handler xylonfb video mode: 1280x720M-16@60 Console: switching to colour frame buffer device 160x45 xylonfb 0 registered xylonfb 1 registered PHY: phy_connect_direct() PHY: phy_attach_direct() PHY: phy_init_hw() ###Vitesse: vsc8221_config_init() phy_write(): regnum=0x1c, val=0x4 mdio_bus.c | mdiobus_write(), addr=0x0, regnum=0x1c, val=0x4, val=4,val=4 mdio_bus.c | mdiobus_write(), state = 2 mdio_bus.c | mdiobus_write(), will write :bus->write xilinx_emacps.c | xemacps_mdio_write() xilinx_emacps.c | xemacps_mdio_write(): will call xemacps_write(), baseaddr=0xd3062000, regval=0x50720004 xilinx_emacps.c | xemacps_mdio_write(): xemacps_write() called, wait for end of transfer
Here the output stops.
This is the function where it stucks...
static int xemacps_mdio_write(struct mii_bus *bus, int mii_id, int phyreg, u16 value) { struct net_local *lp = bus->priv; u32 regval; volatile u32 ipisr; printk("xilinx_emacps.c | xemacps_mdio_write()\n"); regval = XEMACPS_PHYMNTNC_OP_MASK; regval |= XEMACPS_PHYMNTNC_OP_W_MASK; regval |= (mii_id << XEMACPS_PHYMNTNC_PHYAD_SHIFT_MASK); regval |= (phyreg << XEMACPS_PHYMNTNC_PHREG_SHIFT_MASK); regval |= value; printk("xilinx_emacps.c | xemacps_mdio_write(): will call xemacps_write(), baseaddr=0x%x, regval=0x%x\n",lp->baseaddr,regval); xemacps_write(lp->baseaddr, XEMACPS_PHYMNTNC_OFFSET, regval); printk("xilinx_emacps.c | xemacps_mdio_write(): xemacps_write() called, wait for end of transfer\n"); /* wait for end of transfer */ do { cpu_relax(); ipisr = xemacps_read(lp->baseaddr, XEMACPS_NWSR_OFFSET); } while ((ipisr & XEMACPS_NWSR_MDIOIDLE_MASK) == 0); printk("xilinx_emacps.c | xemacps_mdio_write(): end of function\n"); return 0; }
The Devicetree Configuration looks as follows:
... eth@e000b000 { compatible = "xlnx,ps7-ethernet-1.00.a"; reg = <0xe000b000 0x1000>; interrupts = <0 22 4>; interrupt-parent = <&gic>; phy-handle = <&phy0>; phy-mode = "rgmii-id"; xlnx,ptp-enet-clock = <111111111>; xlnx,slcr-div0-1000Mbps = <8>; xlnx,slcr-div0-100Mbps = <8>; xlnx,slcr-div0-10Mbps = <8>; xlnx,slcr-div1-1000Mbps = <1>; xlnx,slcr-div1-100Mbps = <5>; xlnx,slcr-div1-10Mbps = <50>; #address-cells = <0x1>; #size-cells = <0x0>; mdio { #address-cells = <1>; #size-cells = <0>; phy0: phy@0 { compatible = "vitesse,vsc8211"; device_type = "ethernet-phy"; reg = <0>; }; }; }; ...
What can I do? With 14.4 we had no problems.
Thanks for your help!
Helmut
10-24-2013 07:25 AM
Hopefully 14.6 TRD will fix this issue.
Does anybody know if there will be a release soon?
H.
