12-11-2009 02:09 PM
I'm trying to get 2.6.31 from the Xilinx Git repo working on my ML403, and I'm very close, but I've run into a wall.
Some background:
I followed the instructions here http://npg.dl.ac.uk/MIDAS/DataAcq/EmbeddedLinux.html to get 2.6.25-rc9 working. It works very well, and I've set it up to start an ssh server, etc. However, 2.6.25 doesn't seem to have support for the OV534 GSPCA driver, which I need to interface with my camera.
So now I'm trying to get 2.6.31 to work, since it does have support for this driver. However, the only output I can get over the serial port is:
zImage starting: loaded at 0x00400000 (sp: 0x0056deb0)
Allocating 0x325679 bytes for kernel ...
gunzipping (0x00000000 <- 0x0040d000:0x0056cacc)...done 0x2f1e10 bytes
Linux/PowerPC load: ip=off root=/dev/xsa2 rw console=ttyUL0
Finalizing device tree... flat tree at 0x57a300
I've tried several things:
1. Using the reference design from the link about, with a modified virtex405-ml405.dts to match the values from the xparameters_ml403.h file also provided from the link above. However, there seem to be more parameters in the xparameters file than in the device tree file, and I didn't know what to call them, so I wasn't too confident in this working.
2. Making my own bitstream/device tree to build against. I don't have any experience with building a system in an FPGA, so I mostly stuck to the defaults in the wizard.
3. I've tried both UARTLite and the 16550 serial ports, since I've read that some people have had problems with the UARTLite.
4. I've also tried to match the peripheral values to those in the xparameters file from above.
Is there anything I'm missing here?
Would it possible for someone to provide the project files to build a bitstream that will work?
Ryan Fox
12-11-2009 02:30 PM
are you following the directions on our wiki, http://xilinx.wikidot.com?
That generally looks like something is wrong in your device tree. I'm assuming you generated a device tree for project to build the kernel.
You should be able to use your edk project that you were running the old 2.6.25 kernel on fine.
You can compare your device to the one we provide in arch/powerpc/boot/dts/virtex405-ml405.dts.
Make sure you have the console right for sure.
I don't build anything on the ML403 is the problem, I use the ML405, same board, bigger FPGA. The BSB defaults are pretty good for a basic system.
The kernel debug page on the wiki may help also. You should be able to dump the log_buf from memory using XMD to get more info.
I would also recommend to download our ramdisk image and boot from that 1st rather than system ace as it's simpler.
12-12-2009 07:09 PM
I have the same problem. My build elf ran and gave the result as yours. But when I stop the process and check the registers using "rrd". It shows "pc" is jumping between quite low addresses "0x0240" to maybe "0x0260" and never stop. I have not the output further either.
12-14-2009 11:14 PM
For me, I could successfully boot Linux 2.6 on PPC of ML403 board by mainly following XAPP1107.
I could share the built elf file and bit file if you are interested it out. Let me know.
12-15-2009 10:59 AM
12-15-2009 11:34 AM
You can check this.
http://forums.xilinx.com/xlnx/board/message?board.id=ELINUX&thread.id=1705
That means your ramdisk is too large. when you uncompress it. it covers the bootstrap code.
12-16-2009 07:24 AM
If I understand correctly, you're upgrading from 2.6.25 to 2.6.31. Do you have any modules from 2.6.25 in your rootfs? I had the same problem building for 2.6.29 and noticed that I still had 2.6.10 modules in lib/modules. When I removed the "2.6.10" directory the boot continued.
