10-28-2016 03:15 AM
I'm trying to build FSBL (2016.3) from GIT (https://github.com/Xilinx/embeddedsw) following the steps from the README.txt.
I'm running on the zcu102 board, so that should be a matter of just following the few steps there.
That is:
$ source /opt/Xilinx/SDK/2016.2/settings64.sh
$ make clean
$ make "CFLAGS+=-DFSBL_DEBUG_INFO"
And in order for the new version of the FSBL to work, I need update the ATF/BL31, as well.
So I just followed http://www.wiki.xilinx.com/Build+ARM+Trusted+Firmware+(ATF) and cloned https://github.com/ARM-software/arm-trusted-firmware
So:
$ make clean
$ make PLAT=zynqmp RESET_TO_BL31=1 LOG_LEVEL=50
I have a boot.bif that worked with 2016.1 versions of BL31 and FSBL, replacing those two files with the artifacts coming out of the above, is no good. I get a complaint from BL31 about exception level being wrong:
================= In Stage 4 ============ Protection configuration applied Running I =M Xilinx IDCODE 0x4738093 NOTICE: ATF running on XCZU9EG/silicon v1/RTL5.1 at 0xfffea000 VERBOSE: Generic delay timer configured with mult=1 and div=100 VERBOSE: BL31: ATF handoff params at:0xfffe9e00, entries:2 VERBOSE: BL31: 0: entry:0xfffea000, flags:0x0 WARNING: BL31: invalid exception level (0) VERBOSE: BL31: 1: entry:0x8000000, flags:0x0 WARNING: BL31: invalid exception level (0) NOTICE: BL31: Secure code at 0x0 NOTICE: BL31: Non secure code at 0x0
The two entries (0xfffea000 and 0x8000000) seem correct, but their flags not so much.
Any ideas for getting me in right direction is appreciated :)
BR,
Martin Egholm
10-28-2016 09:31 AM
Since 2016.3 we support a more dynamic handoff approach that depends on FSBL passing arguments to the ATF (https://github.com/Xilinx/arm-trusted-firmware/commit/b96f77c65ba5 ).
For the FSBL to populate the argument structure correctly, it in turn depends on the correct attributes being provided through the boot image. Most likely, your issue goes away once you update your '.bif' file similar to this example (notice the 'trustzone' and 'exception_level' partition attributes):
the_ROM_image: { [fsbl_config] a5x_x64 [pmufw_image] xpfw.elf [bootloader] fsbl.elf [destination_cpu=a53-0,exception_level=el-3,trustzone] bl31.elf [destination_cpu=a53-0,exception_level=el-2] u-boot.elf [destination_cpu=a53-0,exception_level=el-1,trustzone] bl32.elf }
10-28-2016 06:33 AM
Just following up on my own post:
Scanning the code, it seems that "all" this exception level "discrimination" is a new feature in the ATF since 2016.2.
Going back to 2016.2 source for both ATF and FSBL things work as expected.
So I reckon I must be missing some build parameters or something when trying to build 2016.3 versions.
10-28-2016 09:31 AM
10-29-2016 12:29 AM
10-31-2016 01:51 AM
