2016.4 petalinux-config u-boot does not store changes
Some of my u-boot changes does not seem to get stored.
I used my 2016.3 u-boot config for the initial setup (seen below as file://defconfig.cfg) and then make changes upon this, which is stored in fragmented configs which get's automatically added.
My u-boot-xlinx_%.bbappend file
SRC_URI_append = " file://platform-top.h"
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
SRC_URI += "file://defconfig.cfg \
            file://user_2017-02-03-07-44-00.cfg;subdir=git \
When I run
petalinux-config -c u-boot
later, I can see some of the changes I made is still there, but for example the I2C Command CONFIG_CMD_I2C is removed.
I also see that this happens when U-boot is built, since the I2C command is also not present, even though I have the following settings as well:
CONFIG_CMD_I2C=y
CONFIG_DM_I2C_COMPAT=y
# CONFIG_DM_I2C_GPIO is not set
# CONFIG_SYS_I2C_FSL is not set
CONFIG_SYS_I2C_CADENCE=y
# CONFIG_SYS_I2C_DW is not set
# CONFIG_SYS_I2C_INTEL is not set
# CONFIG_SYS_I2C_ROCKCHIP is not set
# CONFIG_I2C_MUX is not set
# CONFIG_CROS_EC_KEYB is not set
Any ideas will be appreciated.
Re: 2016.4 petalinux-config u-boot does not store changes
I fixed it by increasing the BBFILE_PRIORITY_meta-user to 7, thus higher than that of the meta-plnx-generated layer. I then put my config's in the meta-user layer.
I just noticed now that whenever I run petalinux-config -c u-boot, the config file in project-spec/meta-plnx-generated/recipes-bsp/u-boot/configs/ get's over written, and contains exactly the settings I can't seem to change. I'll try and see if the configs get loaded in the correct order.
I'm not sure why the u-boot config files should be in meta-plnx-generated as suggested by  AR 68449 instead of meta-user.  It seems as if meta-user's u-boot configs are not loaded after meta-plnx-generated's u-boot configs. I don't know if anyone can confirm or not, or if it is just some of my settings.
It also seems as if meta-plnx-generated's u-boot recipe gets overwritten when petalinux-config --get-hw-description is called, which is troublesome during development or whenever a full build is done.
