Participant larshb
2019.2 FSBL
As of 2019.2, Xilinx Design Suite no longer includes SDK (Eclipse).
I have a Zynq-7000 project implemented in 2019.2 which I want to run PetaLinux on.
So my question is:
How do I generate an FSBL with 2019.2?
Re: 2019.2 FSBL
The petalinux will generate the boot images for you; including the fsbl
Participant larshb
Re: 2019.2 FSBL
Ok, but using previous versions I have modified the FSBL to set up GPIO (enabling UART for debug among others). Are you saying I can do the same, but rather somewhere in the Petalinux configure/build process? I know I can still use petalinux-package --fsbl <my_fsbl>.elf ..., but then I need to build it using older versions of SDK.
Re: 2019.2 FSBL
If you want to make changes to the FSBL in petalinux, then you would need to create a patch and add this to the fsbl recipe in your petalinux project.
for example:
Then in Petalinux project directory
mkdir -p project-spec/meta-user/recipes-bsp/fsbl/files
Copy the patch to the fsbl/files directory
Create the bbappend:
fsbl_%.bbappend
#Force to use embeddedsw repo
EXTERNALXSCTsrc=""
EXTERNALXSCTSRC_BUILD = ""
#Patch FSBL
SRC_URI_append += " file://0001_fsbl_mods.patch"
FILESEXTRAPATHS_prepend := "${THISDIR}/files:"
Or, just use SDK (same version as petalinux), and point to this when doing a petalinux-package
Participant larshb
Re: 2019.2 FSBL
Thank you very much! Your answer is greatly appreciated. When you say SDK same version, do you mean Vitis? So far I have been using earlier releases, but I realize Vitis is also built on top of Eclipse.
Re: 2019.2 FSBL
Yes, that should say SDK/Vitis of the same version as petalinux. So, if 2019.2 it would be Vitis 2019.2, and Petalinux 2019.2.
You can create the FSBL here (with your mods), and point to it during petalinux-package. for example:
petalinux-package --boot --fsbl path/to/your/fsbl --u-boot
Once this all work, you can create the patch using the steps above
