32 bit libs for PetaLinux
Hi!
I run a PetaLinux on a Zynq ZCU104 Kit. Everything is 64 bit.
I have an embedded program which runs on top of Posix, however it needs to be 32 bit.
And it needs to link against 32 bit libraries. So I need them usable next to their 64 bit siblings.
How can I compile the PetaLinux libs for 32 bit?
Or can I generate an entire image running only 32 bit?
Thanks in advance,
Nils
Re: 32 bit libs for PetaLinux
Hi @nilsmontenegro
Follow bellow steps to build rootfs in PetaLinux with multilib support to use a 32-bit application on Zynq UltraScale+ MPSoC.
1. Create a PetaLinux project for your HW and enable the boot mode:
 1. Add the following to <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
DISTRO_FEATURES_remove = "xen"
require conf/multilib.conf
SIGGEN_LOCKEDSIGS_TYPES = ""
2. Add 32 bit applications and packages(For example we have added cpio, util-linux, file packages) you need as shown below <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
IMAGE_INSTALL_append = "lib32-cpio lib32-util-linux lib32-file"
3. When you create apps from petalinux using the command.
$ petalinux-create t apps --name sampleapp
which adds an entry in <plnx-proj-root>/project-spec/meta-user/recipes-core/images/petalinux-user-image.bbappend as mentioned below for 64-bit
IMAGE_INSTALL_append = "sampleapp"
You need to modify this as mentioned below for 32-bit and enable this apps from petalinux-config -c rootfs ---> user packages ---> [*]lib32-sampleapp
IMAGE_INSTALL_append = "lib32-sampleapp"
4. Remove the cache and tmp from your build directory and re-build the project
5. petalinux-build
For your reference :
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842513/Creating+a+multilib+image+for+the+ZCU102+using+Yocto
Thanks & regards
Aravind
Hi!
Thanks for the answer, I tried it during that week. I didn't get to the goal jet.
It increased the compile time from half an hour to 4 hours (why?), so it's hard to try out things.
Also it ends in an error message
checking for "gbm >= 10.2.0"... no
configure: error: Glamor for Xorg requires gbm >= 10.2.0
Which are grafical libraries as far as I know. They are not really needed.in our embedded settings with a serial terminal.
They come after this command:
NOTE: Running ../xorg-server-1.19.3/configure  --build=x86_64-linux
I thought I deactivated xorg-server whith petalinux-config -c rootfs
What to do?
Nils
UPDATE: I saw that libdrm was still activated, it might have dragged in X11 stuff. I deactivated it and am recompiling the stuff now. Let's hope it helps. I am confused anyway, because the error did not happen before I tried to compile 32 bit libs.
These are the 32 bit libs I included: lib32-glibc lib32-libgcc lib32-libstdc++
UPDATE 2: Excluding libdrm didn't help. The error message is:
ERROR: xserver-xorg-2_1.19.3-r0 do_configure: configure failed
[lot's of log]
Did you ever figure this out?  I'm getting the same error and also don't need X11 and am not sure what is pulling it in.
Hi. I never solved any of this. In the end I ported my application to 64 bits.
FYI, I finally got it to build by deselecting all package groups in petalinux-config (specifically, audio, gstreamer, matchbox, v4lutils, x11).  Some of those probably didn't matter, but I didn't need any of them anyway so I just removed all of them and then it stopped trying to build x11 and was able to complete.
