A HOWTO on linking your Xilinx SDK to petalinux with attached bitbake recipe.
I am enclosing a bitbake recipe that will build your SDK application from petalinux.  The link between the two is a SVN repo, but git would work as well.  This recipe also works with target libraries and not just the pre-built ones.  In my example I am linking against the readline library.  Change this as necessary.
All I did was add an app that was the same name as my SDK app using petalinux-create and then dropped this recipe into that bitbake file.  You set your SVN location, the location of your SDK, the build configuration you are using in the SDK, the output binary of the SDK, and the location you want it deployed in your image.
Let me know what your questions are.  It might make a good AR after some peer review.
If you like this, send me a 'Kudo'.
# This file is the mySDKapp recipe.
#this assumes you have a SDK app called mySDKapp and it is sync'ed to the SVN server listed at the SRC_URI location
SUMMARY = "Simple mySDKapp application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "svn://<your svn URL>;module=mySDKapp;protocol=https"
#this example uses a post-build library. Its why we are also passing the "--sysroot...." option to the linker
#Xilinux has an AR describing the setup in the SDK, which we need to override
#https://www.xilinx.com/support/answers/69159.html
DEPENDS += "readline"
S = "${WORKDIR}/mySDKapp"
SRCREV = "${AUTOREV}"
#the location of my SDK install is in /opt/Xilinx/SDK/2017.4  Change this as necessary on your machine.
XILINX_ROOT = "/opt/Xilinx/"
SDK_ROOT = "SDK/2017.4/"
ECLIPSE_ROOT = "eclipse/lnx64.o/eclipse"
JRE_ROOT = "tps/lnx64/jre/bin/"
#set up the environment
DOC_NAV = "DocNav/.settings64-DocNav.sh"
CORE_SCRIPT = ".settings64-XSDK_Core_Tools.sh"
ECLIPSE_PROJECT = "mySDKapp"
#this is the build configuration you want to use from the SDK, typically Debug or Release
ECLIPSE_BUILD_CONFIG = "Debug"
#this is set in the SDK, but defaults to mySDKapp.elf and I typically set it to drop the .elf
ECLIPSE_BINARY = "mySDKapp"
do_compile() {
	${XILINX_ROOT}${DOC_NAV}
	${XILINX_ROOT}${SDK_ROOT}${CORE_SCRIPT}
	${XILINX_ROOT}${SDK_ROOT}${ECLIPSE_ROOT} -vm ${XILINX_ROOT}${SDK_ROOT}${JRE_ROOT} -nosplash -application org.eclipse.cdt.managedbuilder.core.headlessbuild -import ${S} -data ${WORKDIR} -vmargs -Dorg.eclipse.cdt.core.console=org.eclipse.cdt.core.systemConsole
	${XILINX_ROOT}${SDK_ROOT}${ECLIPSE_ROOT} -vm ${XILINX_ROOT}${SDK_ROOT}${JRE_ROOT} -nosplash -application org.eclipse.cdt.managedbuilder.core.headlessbuild -T xilinx.gnu.armv7.linux.c.toolchain.linker.debug xilinx.gnu.c.link.option.ldflags="--sysroot=${TMPDIR}/sysroots/${MACHINE}/"  -build ${ECLIPSE_PROJECT}/${ECLIPSE_BUILD_CONFIG} -data ${WORKDIR} -vmargs -Dorg.eclipse.cdt.core.console=org.eclipse.cdt.core.systemConsole
do_install() {
	install -d ${D}${base_bindir}
	#install the binary to /bin/mySDKapp If you want it somewhere else, change the line below
	install -m 0755 ${ECLIPSE_BUILD_CONFIG}/${ECLIPSE_BINARY} ${D}${base_bindir}
Mentor jmcclusk
Mentor
Re: A HOWTO on linking your Xilinx SDK to petalinux with attached bitbake recipe.
Awesome post, Mark.   Let the kudo's rain down upon you!
Thanks, it's taken about  week to get this to a releasable point.
