conanandai100
A error when generate netlist
I use EDK10.1. The device is Spartan3A. When generating netlist, the following error appears:
ERROR:MDT - C_MEM_CAS_LATENCY0 (mpmc) -
/opt/Xilinx/10.1/ISE/bin/lin/unwrapped/xilperl: error while loading shared
libraries: libdb-4.1.so: cannot open shared object file: No such file or
directory
while executing
"exec xilperl $perlPath -mpmc3
-enable_ecc [xget_hw_parameter_value $mh..."
(procedure "init_control" line 40)
invoked from within
"init_control $mhsinst"
(procedure "::hw_mpmc_v4_00_a::syslevel_update_ctrl_parameter" line 6)
invoked from within
"::hw_mpmc_v4_00_a::syslevel_update_ctrl_parameter 200821064"
ERROR:MDT - IPNAME:mpmc INSTANCE:DDR2_SDRAM -
/opt/Xilinx/10.1/EDK/hw/XilinxProcessorIPLib/pcores/mpmc_v4_00_a/data/mpmc_v2
_1_0.mpd line 180 - error computing override value for C_MEM_CAS_LATENCY0
using tcl
INFO:MDT - IPNAME:DDR2_SDRAM INSTANCE:mpmc -
_1_0.mpd line 215 - tcl is overriding PARAMETER C_PIM0_SUBTYPE value to IXCL
_1_0.mpd line 262 - tcl is overriding PARAMETER C_PIM1_SUBTYPE value to DXCL
_1_0.mpd line 309 - tcl is overriding PARAMETER C_PIM2_SUBTYPE value to PLB
I wonder why...
linnj
Looks like you put this on the wrong forum, this is for Embedded Linux. You should find another forum related to building the h/w.
