AD9371 DRIVERS FOR PETALINUX
I want ad9371 drivers for petalinux . I have downloaded the drivers from https://github.com/analogdevicesinc/linux . While configuring the petalinux using petalinux-config -c kernel i am not able to configure ad9371 drivers as the they are not showing in the drivers list in Drivers support -> Industrial I/O support -> Analog to digital converters.
i want Analog Devices AD9371 RF Transceiver driver driver can you please help ?
Re: AD9371 DRIVERS FOR PETALINUX
<project>/project-spec/meta-user/recipes-modules/adv9371-drv/adv9371-drv.bb
SUMMARY = "Recipe for  build an external ad9371 Linux kernel module"
SECTION = "PETALINUX/modules"
LICENSE = "GPLv2"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/GPL-2.0;md5=801f80980d171dd6425610833a22dbe6"
inherit module
SRC_URI = "file://Makefile \
           file://ad9371.h \
           file://ad9371.c \
           file://ad9371_conv.c \
           file://mykonos/ \
S = "${WORKDIR}"
# The inherit of module.bbclass will automatically name module packages with
# "kernel-module-" prefix as required by the oe-core build environment.
<project>/project-spec/meta-user/recipes-modules/adv9371-drv/files/Makefile
ad9371_drv-y := ad9371.o ad9371_conv.o mykonos/common.o  mykonos/mykonos.o  mykonos/mykonos_gpio.o  mykonos/mykonos_user.o
obj-m += ad9371_drv.o
SRC := $(shell pwd)
all:
    $(MAKE) -C $(KERNEL_SRC) M=$(SRC)
modules_install:
    $(MAKE) -C $(KERNEL_SRC) M=$(SRC) modules_install
clean:
    rm -f *.o *~ core .depend .*.cmd *.ko *.mod.c
    rm -f Module.markers Module.symvers modules.order
    rm -rf .tmp_versions Modules.symvers
 <project>/project-spec/meta-user/recipes-core/images/petalinux-user-image.bbappend
IMAGE_INSTALL_append = " kernel-module-ad9371-drv"
hii
Initially I could not find recipes-modules in meta-user directory so that I have used this command to create recipes-modules "petalinux-create -t modules -n simpmod --enable" i reffered to this link https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2017-3-on-Ubuntu-16-04-can-t-Compile-Kernel-Modules/td-p/852868 but i dint find any of the adv9371-drv directory ??
Create necessary directories and files using mkdir & vi command
