Anonymous
Not applicable
ADA cross-compiler for ZynQ
The arm-xilinx-linux-gnueabi- does not have a compiler for ADA and I have to cross compile ADA codes for the ZynQ platform. I found out that GNAT Pro can cross-compile ADA codes for ZynQ but I have to purchase it in order to use it.
Is there any other alterative to cross-compile ADA for ZynQ on a Linux host?
Any compiler that can generate code for Cortex-A9 should be good enough.
I never looked into it, but I assume gcc can compile ada for ARM. In that case you could e.g. use crosstool-ng to build a x-compiler (http://crosstool-ng.org/).
