AMP - Direct firmware load issue
I'm trying to start a firmware on CPU1 at boot of Petalinux 2017.2.
I successfully copied the firmware in /lib/firmware. I can execute it by those commands below :
    echo cpu1.elf > /sys/class/remoteproc/remoteproc0/firmware
    echo start > /sys/class/remoteproc/remoteproc0/state
    modprobe rpmsg_user_dev_driver
Here is my device tree:
	amba {
                elf_ddr_0: ddr@0 {
                        compatible = "mmio-sram";
                        reg = <0x100000 0x100000>; // memory range and size used by the firmware
	remoteproc0: remoteproc@0 {
		compatible = "xlnx,zynq_remoteproc";
		firmware = "cpu1.elf";
		// two separate interrupts used for signaling between the CPU cores.
		vring0 = <15>;
		vring1 = <14>;
		sram_0 = <&elf_ddr_0>;
The problem is when linux boot up, I get these error messages:
remoteproc remoteproc0: remoteproc@0 is available
remoteproc remoteproc0: Note: remoteproc is still under development and considered experimental.
remoteproc remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
remoteproc remoteproc0: Direct firmware load for firmware failed with error -2
remoteproc remoteproc0: powering up remoteproc@0
NET: Registered protocol family 10
remoteproc remoteproc0: request_firmware failed: -2
I'm a bit confuse because the message still indicate the default firmware name "firmware" instead of "cpu1.elf". When I take a look at /sys/firmware/devicetree/base/remoteproc@0/firmware, I get "cup1.elf". When I do the same thing for /sys/class/remoteproc/remoteproc0/firmware, I get "firmware". So I guess the driver goes into the last path to get the firmware name, but I don't understand why the name is not updated as indicate in the device tree.
Right now, to make the linux and CPU1 boot, I change cup1.elf to firmware. I can now see
remoteproc remoteproc0: Booting fw image firmware, size 574812
virtio_rpmsg_bus virtio0: rpmsg host is online
remoteproc remoteproc0: registered virtio0 (type 7)
Honestly, I would prefer find the right way to execute my firmware with the name cpu1.elf as "firmware" does not tell a lot to someone else tries to debug the linux...
If someone has a solution, I could be very appreciated.
Re: AMP - Direct firmware load issue
Nobody use direct firmware loading ?
