gi4you
AR# 66636 Ubunt core configuration step 1 download error
I am trying to build Ubuntu rootfs following the AR# 66636 reference I found URL error.
Not Found
The requested URL /ubuntu-core/releases/14.04/release/ubuntu-core-14.04.3-core-arm64.tar.gz was not found on this server.
Download a copy of the 64-bit ARM version of Ubuntu Core 14.04 from http://cdimage.ubuntu.com/ubuntu-core/releases/14.04/release/ubuntu-core-14.04.3-core-arm64.tar.gz
Not Found
Can I use this URL link for zcu102 ?
Is it possible Ubuntu 19.04 insted of version 14.04?
http://cdimage.ubuntu.com/ubuntu-base/releases/14.04/release/
http://cdimage.ubuntu.com/ubuntu-base/releases/19.04/release/
Kiman
longley
@gi4you
You can use this below link to download the file.
http://cdimage.ubuntu.com/ubuntu-base/releases/14.04/release/ubuntu-base-14.04.3-core-arm64.tar.gz
And I don't think 19.04 has been tested.
Longley
Versal Blogs
gi4you
booting is Okay with the Ubuntu 14.04.3 LTS.
I can't login root/root.
AR#66636 document explan about login, but I don't understand how to create initramfs.ub.
I am using petalinux 2019.1 and copy the image/linux/image.ub for booting.
here is document said:
>>In order to boot properly, Ubuntu requires that at least one non-root user exist in the filesystem.
>>To do this, boot with the initramfs.ub kernel image created previously.
my bootgmessage:
* Starting save kernel messages [ OK ]
* Starting regular background program processing daemon [ OK ]
* Stopping System V runlevel compatibility [ OK ]
* Stopping save kernel messages [ OK ]
Ubuntu 14.04.3 LTS localhost.localdomain ttyPS0
localhost login: root
root
Login incorrect
localhost.localdomain login: root
Login incorrect
Login timed out after 60 seconds.
Login incorrect
