AXI BRAM write/read
is there example c code on how to access PL Bram via axi bram controller?  I don't have to malloc, just write to the bram address?
Re: AXI BRAM write/read
Hey @s002wjhw
Something like this should work:
        int fd = open("/dev/mem", O_RDWR | O_SYNC);
        .... error checks ...
        void *base = mmap(BRAM_ADDR, BRAM_SIZE,
            PROT_READ | PROT_WRITE, MAP_SHARED,
            fd, NULL);
You need to map the memory region, then you can access it like normal memory.
Hope this helps,
Herbert
Are you interfacing to the BRAM controller via MicroBlaze?  if so, then yes, you just have to read/write from the address using the Xilinx helper Macros:
#include "xil_types.h"
#include "xil_io.h"
#include "xil_printf.h"
#include <inttypes.h>
#define MY_PERIPHERAL_BASE_ADDRESS 0x43000000
int main()
    const uint32_t value = 0xDEADBEAF;
    uint32_t response;
    xil_printf("Writing to BRAM ... ");
    Xil_32Out(MY_PERIPHERAL_BASE_ADDRESS, value);
    xil_printf("Done.\r\n);
xil_printf("Reading from BRAM ... "); response = Xil_32In(MY_PERIPHERAL_BASE_ADDRESS); xil_printf("Done.\r\n); if ( response == value ) xil_printf("SUCCESS!\r\n); else xil_printf("ERROR!!\r\n); return 0; }
Note: I did not compile the above code, it is intended as a reference only.
You can get the address of your block ram controller via the addresses tab in Vivado when the block diagram is open, or from xparameters.h, which is generated inside of the BSP that accompanies your application project in SDK.
Hey @s002wjhw
            fd, NULL);
Hope this helps,
Herbert
yep gotta it working.
if I have axi_dma, how do I access it? this is on zynq petalinux
Newbie curious
Hi Hey @s002wjhw,
We tried using mmap.
Code runs without any error, but I do not see any change in LUT values (in fact it is always 0).
I am not sure, what I might be doing wrong. Do you have any suggestions as you seem more experienced than I.
Many thanks,
Even Iam also using mmap. Can you give me the command for direct compilation of .cpp on zcu102 board.
