Visitor nizarsd
AXI DMA Driver Problem
AXI DMA is not recognised by Linux. The boot log has the following two lines related to AXI DMA
xilinx-vdma 40400000.dma: failed to get axi_aclk (4294967294)
xilinx-vdma: probe of 40400000.dma failed with error -2
The problem is that I have axi_dma and not axi_vdma. Also I checked the axi clock and nothing wrong with it.
After boot, I never see axidma as one of the devices.
Any ideas why this may be happening
Teacher muzaffer
Re: AXI DMA Driver Problem
what does your devicetree entry look like?
Which Xilinx DMA device did you select during Linux Kernel configuration?
Visitor nizarsd
Thanks for you reply. Here is the DMA devices configs
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_AMBA_PL08X is not set
CONFIG_AXI_DMAC=y
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
CONFIG_PL330_DMA=y
CONFIG_XILINX_DMA_ENGINES=y
CONFIG_XILINX_DMATEST=y
# CONFIG_XILINX_VDMATEST is not set
# CONFIG_XILINX_CDMATEST is not set
# CONFIG_XILINX_DPDMA is not set
CONFIG_XILINX_DMA=y
# CONFIG_XILINX_ZYNQMP_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_DW_DMAC_PCI is not set
Participant eduardoparra
Hi, I'm having the same problem on the 2016.3 versión. Did you manage to solve it??
Newbie lbrigante
Hi, I'm also experiencing same problem using Vivado 2016.4 and Petalinux 2016.4. Someone has any idea about this?
[    3.640265] /amba_pl/dma@a0000000: could not get #clock-cells for /amba_pl/misc_clk_0
[    3.640389] ERROR: could not get clock /amba_pl/dma@a0000000:s_axi_lite_aclk(0)
[    3.640577] xilinx-vdma a0000000.dma: failed to get axi_aclk (4294967294)
[    3.640691] xilinx-vdma: probe of a0000000.dma failed with error -2
This error is due to an empty clock node being added to pl.dtsi for the clock that connects to DMA.
misc_clk_0: misc_clk_0 {
To work around this issue, you should add information of the missing clock in system-top.dts. For example:
&misc_clk_0 {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <100>;
As you are using 2016.4 version of tool, ensure you edit the system-top.dts file located under: <plnx-projroot>/project-spec/meta-user/recipes-dt/device-tree/
Debraj
I am getting still same error after adding these in dts file
N JOTHI
Observer simalps
Have you clocked your DMA on Vivado?
You'll do not see any device in /dev/ with the "default" xilinx kernel modules/drivers
Yes. The VDMA is clocked. Works in bare metal.
i do not see any node /dev
hi @lbrigante@nizarsd@jothiadithya,
  At this  new  kernel version(16.4),vdma 、dma 、cdma share the common driver xilinx_dma.c
here is the driver's binding:
https://github.com/Xilinx/linux-xlnx/blob/xilinx-v2016.4/Documentation/devicetree/bindings/dma/xilinx/xilinx_dma.txt
at this binding
https://github.com/Xilinx/linux-xlnx/blob/xilinx-2016.4/Documentation/devicetree/bindings/dma/xilinx/xilinx_dma.txt#L24
the clk device node need to add at your vdma device node.
zynq's common clock device binding file:
https://github.com/Xilinx/linux-xlnx/blob/xilinx-v2016.4/Documentation/devicetree/bindings/clock/zynq-7000.txt
you can use those example of vdma:
axi_vdma_0: axivdma@40030000 {
	compatible = "xlnx,axi-vdma-1.00.a";
	#dma-cells = <1>;
	reg = < 0x40030000 0x10000 >;
	dma-ranges = <0x00000000 0x00000000 0x40000000>;
	xlnx,num-fstores = <0x8>;
	xlnx,flush-fsync = <0x1>;
	xlnx,addrwidth = <0x20>;
	clocks = <&clk 0>, <&clk 1>, <&clk 2>, <&clk 3>, <&clk 4>;
	clock-names = "s_axi_lite_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk",
		      "m_axis_mm2s_aclk", "s_axis_s2mm_aclk";
	dma-channel@40030000 {
		compatible = "xlnx,axi-vdma-mm2s-channel";
		interrupts = < 0 54 4 >;
		xlnx,datawidth = <0x40>;
	dma-channel@40030030 {
		compatible = "xlnx,axi-vdma-s2mm-channel";
		interrupts = < 0 53 4 >;
but i have some confused with the example 's clocks. according to zynq-7000‘s clock binding,<&clk 0>, <&clk 1>, <&clk 2>, <&clk 3>, <&clk 4> refer to
Clock outputs:
 0:  armpll
 1:  ddrpll
 2:  iopll
 3:  cpu_6or4x
 4:  cpu_3or2x
i'm not sure about this,you can try this binding. if can't work you may change those clk device node.may be change to <&clk 15> <&clk 16> <&clk 17> if use  fclk1、fclk2、fclk3 as s_axi_lite_aclk 、m_axi_mm2s_aclk 、m_axi_s2mm_aclk at your ipi design.
BRs
    May be you can use XSDK to generate devicetree.
1.Download the devicetree repo:https://github.com/Xilinx/device-tree-xlnx/releases/tag/xilinx-v2016.4
2.add it to xsdk's repo.
3.more operations refer  to :http://www.wiki.xilinx.com/Build+Device+Tree+Blob
BRs.
Have generated using SDK 2016.4.
Yes. It was clock name issue.
Now I get the following error
[    0.867276] [drm] Initialized drm 1.1.0 20060810
[    0.872515] [drm] load() is defered & will be called again
[    1.435411] [drm] load() is defered & will be called again
[    1.483233] [drm] load() is defered & will be called again
hi @jothiadithya,
    your vdma driver probe well? The vdma print those message "Xilinx AXI VDMA Engine Driver Probed!!"?
*********************** linux has deferred driver probeing mechanism.
The drm driver will retry if they probe fail with the error number:-EPROBE_DEFER.
your error message "[drm] load() is defered & will be called again" print by this line :
https://github.com/Xilinx/linux-xlnx/blob/xilinx-v2016.4/drivers/gpu/drm/xilinx/xilinx_drm_drv.c#L362.
At xilinx_drm_load() function,there are 5 place "goto err_out;" code jump to err_out label.
you need debug the driver to find the issue.(add printk before goto err_out,to find the error reason)
eg:
	private->crtc = xilinx_drm_crtc_create(drm);
	if (IS_ERR(private->crtc)) {
		DRM_DEBUG_DRIVER("failed to create xilinx crtc\n");
		ret = PTR_ERR(private->crtc);
		printk("[%s][%d]ret=%d\n",__func__,__LINE__,ret);
		goto err_out;
 BRs,
HSQ
Thank you for the response. I have a systems which uses VTC, VDMA and VIDEO_OUT. This works fine in standalone system. I try this on linux drm. When the SDk generates the dts file, the vtc is generated for  drivers/media/platform/xilinx/xilinx-vtc. the compatible is ""xlnx,v-tc-6.1". where I am trying use drm. the compatible for this is  "xlnx,v-tc-5.01.a" ( drivers/gpu/drm/xilinx/xilinx_vtc). So I got the error
[    0.867697] [drm] Initialized drm 1.1.0 20060810
[    0.872935] [drm:xilinx_drm_load] *ERROR* failed to get an encoder slave node
I do not use any encoder. The RGB888 drives directly the LCD.
the dts of drm is
    xilinx_drm{
           compatible = "xlnx,drm";
           clocks = <&clkc 16>;
           xlnx,vtc = <&v_tc_0>;
           planes{
                   xlnx,pixel-format = "rgb888";
                   plane0 {
                    dmas = <&axi_vdma_0 1>;
                    dma-names = "vdma0";
Can you let me know what should be the dts?
I have gone thro this already. What would be encoder-slave?
hi
    xilinx use adv7511 as the encoder.  But I don't know what is your encoder?
No encoder used. The lcd is directly driven by axi video out ip.
hi,
    I don't know how to make xilinx drm work without encoder,you can read xililnx drm source  code to work out this.
BRs,
HSQ
Observer sig7p
In my device-tree
vdma_3: axivdma@40020000 {
clock-names = "s_axi_lite_aclk", "m_axi_s2mm_aclk", "m_axi_s2mm_aclk";   <= add
clocks = <&clkc 15>, <&clkc 15>, <&clkc 15>;                                   <= add
reg = <0x40020000 0x10000>;
xlnx,addrwidth = <0x20>;        <= add
xlnx,flush-fsync = <1>;
xlnx,num-fstores = <1>;
#dma-cells = <1>;
dma-channel@40090000 {
interrupt-parent = <&intc>;
interrupts = <0 33 4>;
clocks = <&clkc 15>;
clock-names = "axis";
Observer sig7p
remove some contents. (for petalinux v2016.3)
clock-names = "s_axi_lite_aclk";
#dma-cells = <1>;
