simozz
AXI DMA - UIO driver vs xilinx_dma driver
I have a doubt that I would like to clarify before any change to kernel configuration via petalinux.
In case of using an UIO driver, is it required to disable the AXI DMA kernel driver xilinx_dma ?
As far as I understand it can (and perhaps it's better to) be disabled. Am I right ?
s.
shabbirk
Hi @simozz
You dont need to explicitly disable the DMA support, instead you will have to add compatible = "generic-uio"; under axi_dma device tree node.
You can find example UIO application for AXI component
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842490/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
Best Regards
Shabbir
shabbirk
Hi @simozz
Best Regards
Shabbir
simozz
Thanks for your info, @shabbirk.
s.
