Re: AXI-DMA driver using UIO
I have edited my system-user.dtsi file as shown in the wiki, I have included the memalloc module and I have created my Petalinux. I think I have done everything necessary to run the module but when I run the function ioctl (memAllocFd, MEMALLOC_RESERVE, BUFFER_SIZE * 2) does not reserve the memory, the function dma_alloc_coherent within the module returns NULL. The dmesg command returns this:
[ 346.689147] received command 1 arg 10
[ 346.692751] Reserving buffer 0
[ 346.695780] Allocation failure
This is my system-user.dtsi file
/include/ "system-conf.dtsi"
chosen {
        bootargs = "earlycon clk_ignore_unused   uio_pdrv_genirq.of_id=generic-uio";
        stdout-path = "serial0:115200n8";
        reserved-memory {
                #address-cells = <2>;
                #size-cells = <2>;
                ranges;
                reserved: buffer@0 {
                        compatible = "shared-dma-pool";
                        no-map;
                        reg = <0x0 0x70000000 0x0 0x10000000>;
       reserved-driver@0 {
                 compatible = "xlnx,reserved-memory";
                 memory-region = <&reserved>;
I try to reserve X bytes but it fails. Get the file descriptor of the memalloc but it fails when you run dma_alloc_coherent of the module. I can not find out what else I'm missing.
