edu30692
AXI DMA test driver on Linux
Hi, I'm doing some tests to transfer data from memory to an IP block and back to the memory. Firstly, i'm trying it using a FIFO to create a loopback. I'm working on a zcu102 with Petalinux. When i try to transfer data i cannot start channel.  This is my design on Vivado 2016.1:
Captura de pantalla de 2016-12-21 12:30:19.png
DMA driver works correctly :
[    2.189679] xilinx-dma 80000000.dma: Xilinx AXI DMA Engine driver Probed!!
The code i'm using is from https://forums.xilinx.com/t5/Embedded-Linux/AXI-DMA-with-Zynq-Running-Linux/td-p/522755
When i execute i get :
[   27.251016] xilinx-dma 80000000.dma: Cannot start channel ffffffc073910e18: 10009
[   27.258425] Waiting for DMA to complete...
[   30.260145] DMA timed out
Tags (3)
edu30692
After changing my AXI_DMA IP configuration it worked correctly.
Captura de pantalla de 2016-12-22 10:26:56.png
edu30692
