oabril
AXI GPIO missing in /sys/class/gpio/
I'm tryng to use a AXI gpio in my system but it doesn't show in the /sys/class/gpio/, this is what i'm doing:
Kernels (Xilinx 3.14 and Petalinux 3.17)
Compiled and Build with "make ARCH=arm xilinx_zynq_defconfig" and "make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage"
Device tree:
Axi Gpio node added:
amba_pl: amba_pl {
#address-cells = <1>;
#size-cells = <1>;
compatible = "simple-bus";
ranges ;
axi_gpio_0: gpio@41200000 {
#gpio-cells = <2>;
compatible = "xlnx,xps-gpio-1.00.a";
gpio-controller ;
reg = <0x41200000 0x10000>;
xlnx,all-inputs = <0x0>;
xlnx,all-inputs-2 = <0x0>;
xlnx,all-outputs = <0x1>;
xlnx,all-outputs-2 = <0x0>;
xlnx,dout-default = <0x00000000>;
xlnx,dout-default-2 = <0x00000000>;
xlnx,gpio-width = <0x8>;
xlnx,gpio2-width = <0x20>;
xlnx,interrupt-present = <0x0>;
xlnx,is-dual = <0x0>;
xlnx,tri-default = <0xFFFFFFFF>;
xlnx,tri-default-2 = <0xFFFFFFFF>;
Then, when the system starts with the 3.17 kernel it hangs at the beggining, the 3.14 kernel works, but when i try to find the amba gpio i doesn't show in "/sys/class/gpio".
If i search in the system i found in "/sys/devices/soc0/amba_pl" the axi definition.
Can anybody guide me to know the way to install in the system the gpio?
I just dont really understand how to do it.
I've the same problem! No help?
vanmierlo
Mentor
Mentor
I have no direct answer, but can confirm that it does work with petalinux 2015.2.1 with a generated devicetree. Petalinux 2015.2.1 comes with a 3.19 kernel.
linnj
Did you generate a new FSBL to go along with the h/w design (along with a new Boot.bin) on the SD card?
Petalinux helps you do all this more easily but it can be done outside of Petalinux easily also.
It sounds like the PL did not get enabled to me (clock, reset, level converter) if I'm remembering right.
You should see that using devmem from the Linux command line (without the GPIO in the device tree so it boots ok) will also hang the system.
John
