AXI I2C device tree node.
Can anybody post a correct device tree node for Xilinx AXI I2C IP for Xilinx kernel 3.14.2 which comes with Petalinux 2014.2?
In a hardware design I got 2 PS I2C and 1 PL AXI I2C and I enabled both Cadence and Xilinx I2C drivers in a kernel config. And PS I2C modules getting detected at boot time and work just fine, but not a AXI one.
I tried different 'compatible' strings with no luck including "xlnx,xps-iic-2.00.a" which I found in xilinx i2c driver. If I set it to be Cadence version - it failed to detect clock source and I can't figure out correct clock source for AXI I2C. Anybody got it to work with latest kernel from Xilinx?
Re: AXI I2C device tree node.
Thank you for the only response.
I already solved my problem. Apparently, axy-i2c device tree node must have interrupt defined. In my hardware design I left interrupt unconnected and autogenerated device tree node have interrupt value ommitted, something like "interrupts = <0  4>;" Once I set it to some number driver started to see it. Not sure if I really needed an interrupt, but I went and changed my hardware design to have a real value to set to.
I'm not the one responsible for generating the DTS here, but apparently Vivado generates the following within the _ps.dtsi.
143     ps7_i2c_0: ps7-i2c@e0004000 {
144       bus-id = <0>;
145       clock-frequency = <400000>;
146       clocks = <&clkc 38>;
147       compatible = "cdns,i2c-r1p10";
148       interrupt-parent = <&ps7_scugic_0>;
149       interrupts = <0 25 4>;
150       reg = <0xe0004000 0x1000>;
151       xlnx,has-interrupt = <0x1>;
152       xlnx,i2c-reset = "";
153     } ;
I then have a separate .dtsi that includes the I2C slaves.
 10 &ps7_i2c_0 {
 11   #address-cells = < 1 >;
 12   #size-cells = < 0 >;
 13   q7adc: max11613@34 {
 14     compatible = "maxim,max11613";
 15     reg = <0x34>;
 16     vcc-supply = <&q7_3v3>;
 17   };
 18   q7rtc: ab-rtcmc@56 {
 19     compatible = "abracon,ab-rtcmc";
 20     reg = <0x56>;
 21   };
 22 } ;
How does this compare to what is generated by your tools?
Joshua
Visitor snehaputhani
Did u use cadence driver or xilinx xps-iic driver in the device tree node?
I am facing the same issue with cadence driver, its regarding the input clock source.
axi_iic:i2c@41600000 {
            reg = < 0x41600000 0x10000 >;
            interrupts = <0 32 4>;
            i2c-clk = <100000>;
            input-clk = <111111111>;
            #size-cells = <0>;
            #address-cells = <1>;
The above is my device tree node for axi-i2c.
If i use xilinx driver as shown below:
            compatible = "xlnx,xps-iic-2.00.a";
            xlnx,ten-bit-adr = <0x0>;
            xlnx,gpo-width = <0x1>;
            #size-cells = <0>;
I can see i2c-0 under /dev folder.
But the issue is that read and write always fails with error no 110.  The error is " connection timed out" error.
Participant vijaydhoki
Hi @snehaputhani i'm getting a reg property error while compiling the kernel source ,will you please how to do that .
