AXI IRQ Controller and petalinux 2014.2 device tree generator problem
In a similar situation to this post: http://forums.xilinx.com/t5/Embedded-Linux/Petalinux-driver-for-AXI-Interrupt-Controller-core/td-p/524301 I am trying to extend the number of Zynq PL interrupts with an AXI controller.
After adding an AXI Interrupt controller to my design in Vivado (2014.2),  the petalinux-config now fails to generate the device tree with these errors:
****** hsm v2014.2
**** SW Build 928826 on Thu Jun 5 17:59:37 MDT 2014
** Copyright 1986-2014 Xilinx, Inc. All Rights Reserved.
INFO: [Hsm 55-1698] elapsed time for repository loading 0 seconds
source /opt/petalinux-v2014.2-final/etc/hsm/scripts/petalinux_hsm_bridge.tcl -notrace
can't read "errorCode": no such variable
while executing
"puts stderr "Error code: ${errorCode}.""
(procedure "plnx_error_exit" line 2)
invoked from within
"plnx_error_exit "HSM failed to generate dts""
(procedure "prepare_dt_bsp" line 12)
invoked from within
"prepare_dt_bsp"
invoked from within
"if {[string equal -nocase $target_app "u-boot_bsp"]} {
add_def_ip_list
uboot_config_gen
} elseif {[string equal -nocase $target_app "device-tree"]} ..."
(file "/opt/petalinux-v2014.2-final/etc/hsm/scripts/petalinux_hsm_bridge.tcl" line 443)
INFO: [Common 17-206] Exiting hsm at Wed Sep 24 12:22:58 2014...
5: extra characters after command
ERROR: [Hsm 55-1695] Unknown interrupt sensitivity LEVEL_HIGH:LEVEL_HIGH:LEVEL_HIGH
make[1]: *** [autogen-dts] Error 1
make: *** [post-config-auto-dts] Error 255
I have had a quick look at the tcl code and it seems to be confused by the three (input) interrupt sensitivities with a colon, it is expecting just one.
Does anyone have any ideas here - has this IP been tested/is it supported with petalinux 2014.2, or am I doing something else wrong?
Visitor dev_luciom
Re: AXI IRQ Controller and petalinux 2014.2 device tree generator problem
I encounter the same problem,trying to connect 4 interrupt lines to an "AXI Interrupt Controller" via a "Concat" IP. I also use Vivado 2014.2 and Petalinux 2014.2. Have you find a solution to your problem?
ERROR: Failed to post config linux
ERROR: Failed to config subsystem linux.
ERROR: [Hsm 55-1695] Unknown interrupt sensitivity EDGE_RISING:EDGE_RISING:EDGE_RISING:EDGE_RISING
Thanks in advance.
Best regards,
Sylvain
Participant eduardoparra
I have the same problem, did you manage to solve it??
