badFITimage
AXI Interrupt Controller IRQ note registering as GIC periph in Linux
Hi, I have a simple design to test an external active low edge triggered interrupt. The signal is connect to an instance of the AXI INTC block in the following way:
With the following device tree:
	amba_pl: amba_pl@0 {
		#address-cells = <2>;
		#size-cells = <2>;
		compatible = "simple-bus";
		ranges ;
		gpio_1553: gpio@a0000000 {
			#gpio-cells = <3>;
			#interrupt-cells = <2>;
			clock-names = "s_axi_aclk";
			clocks = <&zynqmp_clk 71>;
			compatible = "xlnx,axi-gpio-2.0", "xlnx,xps-gpio-1.00.a";
			gpio-controller ;
			interrupt-controller ;
			interrupt-names = "ip2intc_irpt";
			interrupt-parent = <&axi_intc_0>;
			interrupts = <1 2>;
			reg = <0x0 0xa0000000 0x0 0x1000>;
			xlnx,all-inputs = <0x0>;
			xlnx,all-inputs-2 = <0x0>;
			xlnx,all-outputs = <0x0>;
			xlnx,all-outputs-2 = <0x0>;
			xlnx,dout-default = <0x00000000>;
			xlnx,dout-default-2 = <0x00000000>;
			xlnx,gpio-width = <0x1>;
			xlnx,gpio2-width = <0x20>;
			xlnx,interrupt-present = <0x1>;
			xlnx,is-dual = <0x0>;
			xlnx,tri-default = <0xFFFFFFFF>;
			xlnx,tri-default-2 = <0xFFFFFFFF>;
		psu_ctrl_ipi: PERIPHERAL@ff380000 {
			/* This is a place holder node for a custom IP, user may need to update the entries */
			compatible = "xlnx,PERIPHERAL-1.0";
			reg = <0x0 0xff380000 0x0 0x80000>;
		psu_message_buffers: PERIPHERAL@ff990000 {
			reg = <0x0 0xff990000 0x0 0x10000>;
		axi_intc_0: interrupt-controller@a0001000 {
			compatible = "xlnx,axi-intc-4.1", "xlnx,xps-intc-1.00.a";
			interrupt-parent = <&gic>;
			interrupts = <0 89 4>;
			reg = <0x0 0xa0001000 0x0 0x1000>;
			xlnx,kind-of-intr = <0x3>;
			xlnx,num-intr-inputs = <0x2>;
&spi1 {
	status = "okay";
	num-cs = <1>;
	label = "MY-SPI-DEVICE";
	is-decoded-cs = <0>;
	hi6131_0: hi6131@0 {
		compatible="poc,hi6131";
		reg = <0>;
		spi-max-frequency = <20000000>;
		/* Interrupt Parent Set to AXI INTC */
		interrupt = <0 2>;
Upon kernel boot, the intc driver is probed and results in:
irq-xilinx: /amba_pl@0/interrupt-controller@a0001000: num_irq=2, edge=0x3
[    2.488148] No set_type function for IRQ 48 (interrupt-controller@a0001000)
But results in no AXI INTC periph registering as a GIC device.
# cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
  0:          0          0          0          0     xgpio   0 Edge      hi6131Int
  4:       1765       1742       1594       1582     GICv2  30 Level     arch_timer
  7:          0          0          0          0     GICv2  67 Level     zynqmp_ipi
  8:          0          0          0          0     GICv2 175 Level     arm-pmu
  9:          0          0          0          0     GICv2 176 Level     arm-pmu
 10:          0          0          0          0     GICv2 177 Level     arm-pmu
 11:          0          0          0          0     GICv2 178 Level     arm-pmu
 12:          0          0          0          0     GICv2 155 Level     axi-pmon, axi-pmon
 13:          0          0          0          0     GICv2 156 Level     zynqmp-dma
 14:          0          0          0          0     GICv2 157 Level     zynqmp-dma
 15:          0          0          0          0     GICv2 158 Level     zynqmp-dma
 16:          0          0          0          0     GICv2 159 Level     zynqmp-dma
 17:          0          0          0          0     GICv2 160 Level     zynqmp-dma
 18:          0          0          0          0     GICv2 161 Level     zynqmp-dma
 19:          0          0          0          0     GICv2 162 Level     zynqmp-dma
 20:          0          0          0          0     GICv2 163 Level     zynqmp-dma
 22:          0          0          0          0     GICv2 109 Level     zynqmp-dma
 23:          0          0          0          0     GICv2 110 Level     zynqmp-dma
 24:          0          0          0          0     GICv2 111 Level     zynqmp-dma
 25:          0          0          0          0     GICv2 112 Level     zynqmp-dma
 26:          0          0          0          0     GICv2 113 Level     zynqmp-dma
 27:          0          0          0          0     GICv2 114 Level     zynqmp-dma
 28:          0          0          0          0     GICv2 115 Level     zynqmp-dma
 29:          0          0          0          0     GICv2 116 Level     zynqmp-dma
 31:          0          0          0          0     GICv2  93 Level     eth0, eth0
 33:        122          0          0          0     GICv2  49 Level     cdns-i2c
 34:          0          0          0          0     GICv2  50 Level     cdns-i2c
 35:          0          0          0          0     GICv2  42 Level     ff960000.memory-controller
 36:          0          0          0          0     GICv2  57 Level     axi-pmon, axi-pmon
 37:          0          0          0          0     GICv2  47 Level     ff0f0000.spi
 38:          0          0          0          0     GICv2  58 Level     ffa60000.rtc
 39:          0          0          0          0     GICv2  59 Level     ffa60000.rtc
 40:         86          0          0          0     GICv2  81 Level     mmc0
 41:          0          0          0          0     GICv2  51 Level     ff040000.spi
 42:       1232          0          0          0     GICv2  52 Level     ff050000.spi
 43:        176          0          0          0     GICv2  53 Level     xuartps
 46:          0          0          0          0     GICv2  84 Edge      ff150000.watchdog
 47:          0          0          0          0     GICv2  88 Level     ams-irq
IPI0:       568       2160        344       2336       Rescheduling interrupts
IPI1:         3          5          1          5       Function call interrupts
IPI2:         0          0          0          0       CPU stop interrupts
IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
IPI4:         0          0          0          0       Timer broadcast interrupts
IPI5:         0          0          0          0       IRQ work interrupts
IPI6:         0          0          0          0       CPU wake-up interrupts
Err:          0
jkarch1948
Did you ever find out what interrupt-parent and interrupt settings work for your AXI GPIO device?
badFITimage
The device tree parameters ended up being correct and worked. The issue was with how we were handling the irq in our custom driver.
