AXI SPI driver bug in petalinux 2018.2 for 32bit or 16bit wordsize
Dear Xilinx support,
there is most certainly a massive bug in the pointer arithmetic inside the axi_spi's driver for the 2018.2 petalinux kernel. The functions
xspi_read_rx_fifo and xspi_fill_tx_fifo are both using wrong access methods to xqspi->rx_ptr and xqspi->tx_ptr in my opinion.
This results in wrong spi transfers. For TX only the least significant byte is transferred. For RX the buffer will be corrupted.
I attach a proposal for a patch to this post. The patch suggests a minimal change to two lines of the driver. Efficiency could be better when changing the increment behaviour of the loop variable i instead.
Comments are highly welcome.
Leave Kudos if you find this patch useful. At my side I was successfully able to do 32bit spi transfers after applying this patch.
Sebastian
thanks for your post, @sgeorgi_sen ! I have exactly the problem you are describing, sending 32 Bits, but the first 24 Bits are all zeros. After reading lots of posts and trying different things, I hope your post might solve my problem, as I am using Petalinux 2018.2. I am trying to AXI SPI with
Where can I find spi-xilinx.c file to add your patch? I would really appreciate your help.
Best regards
Hi @Nizlas ,
the best way to add the patch to the kernel is the bitbake procedure of petalinux. I assume, that you are in your petalinux project folder:
mkdir -p project-spec/meta-user/recipes-kernel/linux/files
cp spi-xilinx.c.patch project-spec/meta-user/recipes-kernel/linux/files
echo "FILESEXTRAPATHS_prepend := \"\${THISDIR}/files:\"" > project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%.bbappend
echo "SRC_URI += \"file://spi-xilinx.c.patch\"" >> project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%.bbappend
then call petalinux-builld. The patch should be applied to the kernel.
I use the same method to add my config options to the kernel build:
cp user_kernel.cfg project-spec/meta-user/recipes-kernel/linux/files
echo "SRC_URI += \"file://user_kernel.cfg\"" >> project-spec/meta-user/recipes-kernel/linux/linux-xlnx_%.bbappend
The user_kernel.cfg contains lines such as
CONFIG_SPI_SPIDEV=y
and so on.
I hope that helps.
Sebastian
Hi @Nizlas ,
has the patch worked?
In this case you could mark the post as accepted solution.
Sebastian
Hi Sebastian,
unfortunately the patch did not solve my problem. Not because your patch did not work, but because of another problem.
The spi driver I was using handles all messages in 8 bit packages. Therefore I had to change my settings in my IP to 8 Bit, although I am transmitting 32 bit messages.
Anyway, thanks again for your support.
