04-26-2017 02:54 AM
Hi, We are trying to run the latest versions on master branch of linux-xlnx (4.9 kernel) and u-boot-xnlx on a zynqmp(xczu3eg) board with our own Yocto recipes. We previously ran something based on 4.6 and the upgrade to latest on 4.9 and Vivado 2017.1. This upgrade has solved some of our previously problems but now we have a new one:
We have 8 AXI timers in the FPGA accessed with our own driver and when we try to read from them everything hangs.
Our pl.dtsi (included in our device tree) looks like this:
/ { amba_pl: amba_pl@0 { #address-cells = <2>; #size-cells = <2>; compatible = "simple-bus"; ranges ; axi_timer_0: timer@a0000000 { clock-frequency = <99998999>; clocks = <&misc_clk_0>; compatible = "xlnx,xps-timer-1.00.a"; interrupt-parent = <&gic>; interrupts = <0 89 4>; reg = <0x0 0xa0000000 0x0 0x10000>; xlnx,count-width = <0x20>; xlnx,gen0-assert = <0x1>; xlnx,gen1-assert = <0x1>; xlnx,one-timer-only = <0x0>; xlnx,trig0-assert = <0x1>; xlnx,trig1-assert = <0x1>; }; axi_timer_1: timer@a0010000 { .. }; .. .. axi_timer_7: timer@a0070000 { .. };psu_ctrl_ipi: PERIPHERAL@ff380000 { compatible = "xlnx,PERIPHERAL-1.0"; reg = <0x0 0xff380000 0x0 0x80000>; }; psu_message_buffers: PERIPHERAL@ff990000 { compatible = "xlnx,PERIPHERAL-1.0"; reg = <0x0 0xff990000 0x0 0x10000>; }; misc_clk_0: misc_clk_0 { #clock-cells = <0>; clock-frequency = <99998999>; compatible = "fixed-clock"; }; }; };
This also hangs:
>devmem2 0xa0000000
So any idea how to solve this? It worked with a previous kernel.
04-27-2017 08:07 AM
In our dts file I changed the include from:
/include/ "zynqmp-clk-ccf.dtsi"
to:
/include/ "zynqmp-clk.dtsi"
and then it seemed to work, but this doesn't seem to be the correct solution. As I understand it some other components that we are going to use is dependent on the common clock framework.
So perhaps we can use the common clock framework if we change misc_clk_0 to something else?
08-24-2017 10:41 AM
Thank you for posting your solution. I was experience the same issue when trying to access my AXI_IIC controllers. Your solution fixed my problem. too
08-25-2017 02:33 AM - edited 08-25-2017 02:54 AM
Hi per.h.johnsson@afconsult.com
From where is coming that miscellaneous clock? Is it an external clock?
Are you loading the PMU FW?
08-25-2017 06:56 AM
For me at least, the device tree files are generated by SDK.
Yes, the PMU FW is loaded.
08-27-2017 07:56 PM
I guess Linux turned off PL clock. Try to add "clk_ignore_unused" in bootargs and check the results.
09-12-2017 06:47 AM
I went back to using zynqmp-clk-ccf.dtsi and added "clk_ignore_unused: to my bootargs.
AXI accesses to IP in the PL works again. Thanks
09-15-2017 02:34 AM
09-15-2017 04:35 AM
I did not start this thread so I do not think I should mark it solved.
I just contributed and posted my results in case it helps anyone else.
09-15-2017 04:37 AM
01-04-2018 01:35 PM
Hi, we also ran into this same issue, and we are now able to read axi space after using the bootarg shown.
Based on Documentation/clk.txt, it seems like this is not a good long term solution though, what do you think?
