AXI registers read /write access from userspace
I want to do read and write access to AXI registers from userspace, is there any xilinx APIs defined instead of using /dev/mem and creating custom APIs.
Please suggest
Re: AXI registers read /write access from userspace
Hi @umamahesh
You can try enabling UIO userspace, as explained in this forum link to acheive read/write without devmem/mmap
https://forums.xilinx.com/t5/Embedded-Linux/How-to-access-AXI-registers-under-Petalinux/td-p/829599
I have added some simple code here that you can use to read/write a register:
You can build this in SDK, or create a makefile:
APP = reg_read
# Add any other object files to this list below
APP_OBJS = read_write.o
all: $(APP)
$(APP): $(APP_OBJS)
    $(CC) $(LDFLAGS) -o $@ $(APP_OBJS) $(LDLIBS)
clean:
    -rm -f $(APP) *.elf *.gdb *.o $(APP_OBJS)
%.o: %.c
    $(CC) -c -Wall -O0 -g3 -c -fmessage-length=0 -MT"$@" -MMD -MP -MF"$(@:%.o=%.d)" -MT"$(@)" -o "$@" "$<"
Clean. Thanks for that code, it helps alot.
