Visitor rkthebest
AXI timer interrupt in linux
i am using custom made linux by yocto with Zynq Zybo Z7 development board.
and i want to react to the interrupt generated by PL in the linux system.
but have not got any success.
i am using the following vivado design.
the interrupt is connected to PL-PS [0].
i am using the following pl.dtsi generated by vivado SDK
 * CAUTION: This file is automatically generated by Xilinx.
 * Version:
 * Today is: Tue Dec 11 14:06:18 2018
	amba_pl: amba_pl {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "simple-bus";
		ranges ;
		axi_timer_0: timer@42800000 {
			clock-frequency = <100000000>;
			clock-names = "s_axi_aclk";
			clocks = <&clkc 15>;
			compatible = "xlnx,xps-timer-1.00.a";
			interrupt-names = "interrupt";
			interrupt-parent = <&intc>;
			interrupts = <0 29 4>;
			reg = <0x42800000 0x10000>;
			xlnx,count-width = <0x20>;
			xlnx,gen0-assert = <0x1>;
			xlnx,gen1-assert = <0x1>;
			xlnx,one-timer-only = <0x1>;
			xlnx,trig0-assert = <0x1>;
			xlnx,trig1-assert = <0x1>;
and following driver for registering the interrupt
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/interrupt.h>
#include <linux/irq.h>
#include <linux/platform_device.h>
#include <linux/slab.h>
#include <asm/io.h>
MODULE_LICENSE("GPL");
#define DEVICE_NAME "xilaxitimer"
#define IRQ_NUM		61
#define XIL_AXI_TIMER_BASEADDR 0x41C00000
#define XIL_AXI_TIMER_HIGHADDR 0x41C0FFFF
#define XIL_AXI_TIMER_TCSR_OFFSET		0x0
#define XIL_AXI_TIMER_TLR_OFFSET		0x4
#define XIL_AXI_TIMER_TCR_OFFSET		0x8
#define XIL_AXI_TIMER_CSR_INT_OCCURED_MASK	0x00000100
#define XIL_AXI_TIMER_CSR_CASC_MASK		0x00000800
#define XIL_AXI_TIMER_CSR_ENABLE_ALL_MASK	0x00000400
#define XIL_AXI_TIMER_CSR_ENABLE_PWM_MASK	0x00000200
#define XIL_AXI_TIMER_CSR_ENABLE_TMR_MASK	0x00000080
#define XIL_AXI_TIMER_CSR_ENABLE_INT_MASK	0x00000040
#define XIL_AXI_TIMER_CSR_LOAD_MASK		0x00000020
#define XIL_AXI_TIMER_CSR_AUTO_RELOAD_MASK	0x00000010
#define XIL_AXI_TIMER_CSR_EXT_CAPTURE_MASK	0x00000008
#define XIL_AXI_TIMER_CSR_EXT_GENERATE_MASK	0x00000004
#define XIL_AXI_TIMER_CSR_DOWN_COUNT_MASK	0x00000002
#define XIL_AXI_TIMER_CSR_CAPTURE_MODE_MASK	0x00000001
#define TIMER_CNT	0xF8000000
static struct platform_device *pdev;
void *dev_virtaddr;
static int int_cnt;
static irqreturn_t xilaxitimer_isr(int irq,void*dev_id)
  unsigned int data;
   * Check Timer Counter Value
  data = ioread32(dev_virtaddr + XIL_AXI_TIMER_TCR_OFFSET);
  printk("xilaxitimer_isr: Interrupt Occurred ! Timer Count = 0x%08X\n",data);
   * Clear Interrupt
  data = ioread32(dev_virtaddr + XIL_AXI_TIMER_TCSR_OFFSET);
  iowrite32(data | XIL_AXI_TIMER_CSR_INT_OCCURED_MASK,
   * Disable Timer after 100 Interrupts
  int_cnt++;
  if (int_cnt>=100)
      printk("xilaxitimer_isr: 100 interrupts have been occurred. Disabling timer");
      iowrite32(data & ~(XIL_AXI_TIMER_CSR_ENABLE_TMR_MASK),
  return IRQ_HANDLED;
static int __init xilaxitimer_init(void)
  unsigned int data;
  int_cnt = 0;
  printk(KERN_INFO "xilaxitimer_init: Initialize Module \"%s\"\n", DEVICE_NAME);
   * Register ISR
  if (request_irq(IRQ_NUM, xilaxitimer_isr, 0, DEVICE_NAME, NULL)) {
    printk(KERN_ERR "xilaxitimer_init: Cannot register IRQ %d\n", IRQ_NUM);
    return -EIO;
  else {
    printk(KERN_INFO "xilaxitimer_init: Registered IRQ %d\n", IRQ_NUM);
   * Map Physical address to Virtual address
  dev_virtaddr = ioremap_nocache(XIL_AXI_TIMER_BASEADDR,
				 XIL_AXI_TIMER_HIGHADDR - XIL_AXI_TIMER_BASEADDR + 1);
   * Set Timer Counter
  iowrite32(TIMER_CNT,
	    dev_virtaddr + XIL_AXI_TIMER_TLR_OFFSET);
  data = ioread32(dev_virtaddr + XIL_AXI_TIMER_TLR_OFFSET);
  printk("xilaxitimer_init: Set timer count 0x%08X\n",data);
   * Set Timer mode and enable interrupt
  iowrite32(XIL_AXI_TIMER_CSR_LOAD_MASK,
  iowrite32(XIL_AXI_TIMER_CSR_ENABLE_INT_MASK | XIL_AXI_TIMER_CSR_AUTO_RELOAD_MASK,
   * Register Device Module
  pdev = platform_device_register_simple(DEVICE_NAME, 0, NULL, 0);
  if (pdev == NULL) {
    printk(KERN_WARNING "xilaxitimer_init: Adding platform device \"%s\" failed\n", DEVICE_NAME);
    kfree(pdev);
    return -ENODEV;
   * Start Timer
  iowrite32(data | XIL_AXI_TIMER_CSR_ENABLE_TMR_MASK,
  return 0;
static void __exit xilaxitimer_edit(void)
   * Exit Device Module
  iounmap(dev_virtaddr);
  free_irq(IRQ_NUM, NULL);
  platform_device_unregister(pdev);
  printk(KERN_INFO "xilaxitimer_edit: Exit Device Module \"%s\".\n", DEVICE_NAME);
module_init(xilaxitimer_init);
module_exit(xilaxitimer_edit);
MODULE_AUTHOR ("Xilinx");
MODULE_DESCRIPTION("Test Driver for Zynq PL AXI Timer.");
MODULE_LICENSE("GPL v2");
MODULE_ALIAS("custom:xilaxitimer");
but when i insert the module, i always get the error message that cannot register IRQ 61
root@zybo-zynq7:~# insmod axitimer.ko
xilaxitimer_init: Initialize Module "xilaxitimer"
xilaxitimer_init: Cannot register IRQ 61
insmod: can't insert 'axitimer.ko': Input/output error
also i do not see any timer message in the boot log
what i am doing wrong?
Tags (4)
Visitor sunnerxu
Re: AXI timer interrupt in linux
Most of your code is right. Maybe you can set
#define IRQ_NUM 49
and try again.
and result is below:
Visitor sunnerxu
And you may use platform_get_irq instead of request_irq directly.
