Access LEDs from Linux on Zynq ZC706
Is there a mechanism to access (turn on/off) LEDs on Zynq ZC706 board from Linux? Accessing registers via mmap of /dev/mem would be fine. I am hoping that the LEDs are connected to the PS and no changes to PL are required/necessary.
Is that correct? I looked and searched a few user guide but didn't see anything on how to control LEDs from PS without building an FPGA image. Any tips/pointers greatly appreciated.
Please check if below discussion helps
http://forums.xilinx.com/t5/Embedded-Linux/How-do-I-access-GPIO-on-ZedBoard-using-the-latest-Petalinux/td-p/365741
Also this AR
http://www.xilinx.com/support/answers/51786.html
Vanitha
AFAIK, all LEDs on the zc706 are connected to PL pins. So, at a bare minimum, you need a bitstream that routes those pins to the PS GPIO on the EMIO interface.
Once there you should use the gpio-led driver to control the LEDs.
http://forums.xilinx.com/t5/Embedded-Linux/Blink-LEDs-in-Linux-on-Zynq-through-dev-mem/m-p/534365/highlight/true#M10996
http://www.wiki.xilinx.com/Linux+GPIO+Driver#Linux%20Kernel%20Drivers-LEDS-GPIO%20Driver
Thanks sorenb. I was hoping that I don't hav eto build a bitstream for driving LEDs on ZC706 but will look into building one now. Thanks for the pointer to the Wiki page which is very useful.
