Access to UART Lite Registers in Linux
I built a system with a few APIs: UART Lite, UART 16550, GPIO AXI and BRAM AXI to run Linux (Petalinux or Ubuntu). I avoid using kernel modules and prefer mmap() to read-write peripheral registers directly. All of these IPs work as expected, except for UART Lite. I can read and write TX register(it sends data to the assigned pin without problems), control and status too but if I attempt to read RX FIFO my Linux application crashes with "Bus Error" message. I've seen high-level access examples via /dev/ttyXXX, is this the best way to do it? I still have not tried tty option, for me it seems to be too slow. So, the question is how to solve the bus error when reading mapped RX FIFO of UART Lite?
Is the RX FIFO a read only register?
Per PG142 "The RX FIFO is a read-only register. Issuing a write request to this register has no effect." In my case bus error happens when I try to read. I tried reading both when RXFIFO Valid Data bit is set and when the bit is 0, any read operation on RX FIFO results in bus error.
Can you share your code
Of course. The actual code is quite big, so I'll post pieces relatet to uart lite.
1. Acquire remapped address
mem_fd=open("/dev/mem", O_RDWR|O_SYNC);
off_t uli_base = mmap(0, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, mem_fd, uli_base_off);
'uli_base' now is pointing to UART Lite AXI registers. The argument uli_base_off is the UART Lite AXI address from Vivado project.
2. Simplest way send /receive:
void ul_put_char(uint8_t char_to_send){
*((volatile unsigned long *) (uli_base + ULT_OFFS_TXFIFO))=char_to_send;
uint8_t ul_get_char(){
uint8_t ret= *((volatile unsigned long *) (uli_base + ULT_OFFS_RXFIFO));
return ret;
The ULT_OFFS_TXFIFO and RXFIFO defined per pg142:
#define ULT_OFFS_RXFIFO 0x0
#define ULT_OFFS_TXFIFO 0x4
#define ULT_OFFS_STAT 0x8
3. To see if the RX buffer has data I use
uint8_t  get_ulite_status(){
uint8_t ret=(*((volatile unsigned long *) (uli_base + ULT_OFFS_STAT)))&0xFF;
return ret;
The functions get_ulite_status() and ul_put_char() work fine, i.e. status is either 4 (no communications) or 7 (a lot of data sent to UART, in particular GPS stream), but ul_get_char() only gives bus error and crashes the application.
Two more details:
- this way works fine with UART 16550 (just a little more mess with registers)
- I used Ultra96 BSP and did not touch device tree. To be more exact I tried to update it as described on the Xilinx drivers "Confluence" web page for UART Lite, but it did not have any effect and I reverted back to unedited system-user.dtsi
