Observer petervuto
Accessing physical memory from an interrupt handler
Hey guys. I'm writing a kernel module for a design in the PL. Sometimes the PL sends an interrupt to the PS, and I need to respond by reading some data from the PL and maybe telling it to deassert the interrupt by writing to the usual 0x43c000.. control area.
How do I write to a physical address like 0x43c00000 from an interrupt handler?
In non-atomic kernel code, I've accomplished all such communication with the PL by calling ioremap() on the relevant physical address and then iowrite/ioreading it. In the interrupt handler however, as soon as I call the ioremap_nocache(), I get an ugly kernel panic - https://pastebin.com/D84vgc5v . That stack trace ends at __get_vm_area_node, and googling for that function I got to http://elixir.free-electrons.com/linux/v4.0/source/mm/vmalloc.c#L1308, where on line 1315 there's the ominous
BUG_ON(in_interrupt());
I assume that ioremap uses vmalloc in the background, and thus ioremap_nocache() is not what I should be using? But what then?
Visitor msteveb0
Re: Accessing physical memory from an interrupt handler
If you check many of the Linux kernel drivers you will see a common pattern of doing an ioremap() (or equivalent) in the probe function, and then the rest of the driver, including the irq handler can access the control registers through that mapping.
Visitor msteveb0
ioremap maps a physical address to virtual address so that it can be accessed.  I wouldn't think that this requires any vmalloc calls since there is no any allocation going on but clearly is something that can't be called from interrupt context.  However, as mentioned by @msteveb0 you generally call  ioremap earlier in the driver  and often save the address in a global that can be easily accessed from the interrupt handler.
Observer petervuto
Thanks folks!
