Acknowledging Interrupts
All,
I have written a custom device driver for a peripheral contained with a Virtex 4 FPGA.  I have and interrupt that fires when a FIFO becomes full.  I would like to know at what levels do I need to explicitly acknowledge this interrupt or does the linux kernel and associated driver for the Xilinx interrupt controller handle acknowledgement?  More specifically,  do I need code to acknowledge the interrupt at the IP level, the Device level, and at the interrupt controller level?
-David
Re: Acknowledging Interrupts
Hi David,
In general the kernel takes care of the interrupt controller. You just need to take care of the IP in the handlers assuming you connect the handlers to the kernel with the request_irq call.
Our emaclite driver is not a bad example as it's not real big (drivers/net/xilinx_emaclite.c).
