Visitor dfantoni
Add PHP interpreter to Petalinux 2018.3 installation
Hi everybody!
I'm trying to add PHP interpreter to Petalinux 2018.3 on Zynq-7000 in order to work with busybox httpd (if possible)
Since I cannot find the php package in rootfs configuration how can I add it to my installation?
Thanks in advance!
Re: Add PHP interpreter to Petalinux 2018.3 installation
Try adding this to project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend
IMAGE_INSTALL_append = " php"
and enable in php in petalinux-config -c rootfs -> User packages ->
Best Regards
Shabbir
Visitor dfantoni
Thanks for the help but now in the final image i find only phpdbg executable and therefore i can not use the interpreter with httpd.
Do I have to install some other packages?
Best
Daniele
Try adding php-cli also and see if that helps.
Note: Adding packages to petalinux is as good as adding packages in yocto
Best Regards
Shabbir
