Observer k4rm4n
Add python (or any rpm) on Petalinux
Thanks all for read me.
I need to add Python in my Petalinux image.
1- In petalinux 2016.1 i can see  python rpm packages (for example python-core-2.7.9-r1.cortexa9hf_vfp_neon.rpm) in the folder:
/opt/pkg/petalinux-v2016.1-final/components/packages-repo/plnx-repo/rpm/cortexa9hf_vfp_neon
If i try to add this packages:
petalinux-config -c rootfs --> Root file system package --> I DONT SEE ANY python option.
2 - Additionally I tried to use yocto with meta-petalinux. I was able to build the python packages with the rpm result. In this point i obtain the same rpms as first point (for example python-core-2.7.9-r1.cortexa9hf_vfp_neon.rpm) but I dont know how to add this packages in my petalinux image.
I tried bymyself find information about this, but nothing clear and I am not an expert. Any help, hint or solution will be very welcome.
Regards.
Re: Add python (or any rpm) on Petalinux
hi, petalinux16.4 contain python,you can use petaconfig -c rootfs to select it.
 -> Filesystem Packages
     -> devel
         -> python
              -> python
tips: your can use / to search,and then type “python”and enter to search.
then press 1 to jump to the configuration.
BRs,
Scholar austin
k,
Have you read through the threads here on the subject?  Search for zynq python
Austin Lesea
Principal Engineer
Xilinx San Jose
check this related post
https://forums.xilinx.com/t5/Embedded-Linux/How-to-add-applications-to-petalinux/td-p/490012
Thanks and Regards
Balkrishan
Observer k4rm4n
Thanks for your answers,
All post i reviewed doesnt show clear information. In Petalinux manual and yocto wiki also i cannot see information about how to load packages in petalinux image.
Could i merge the rootfs from yocto with the packages i want with the petalinux one?
Observer k4rm4n
I added python with petalinux 2016.1 (originally i had 2015.4 and I didnt source the 2016.1 seetings.sh).
Even i added from petalinux, is there any way to add other custom packages compiled with yocto?
@k4rm4n
I think you can add custom package to petalinux.
Refer to the below answer record which has the details you are looking for.
How to add package to Petalinux - http://www.xilinx.com/support/answers/67160.html
How do I add a script to my PetaLinux root file system that runs at startup?- http://www.xilinx.com/support/answers/55998.html
Achutha
Scholar austin
see Steve blog:  PYNQ
Austin Lesea
Principal Engineer
Xilinx San Jose
Participant rankeney
FWIW, I have cross-compiled Python 2.7.3 for the Zynq platform. You can find it at:
https://www.dropbox.com/s/r5zh3qpl647rf9m/Python-2.7.3.tar.gz?dl=0
Hopefully you have an ext4 partition on your SD card. You can create a /usr/local directory there and extract the archive into that folder.
I am in the same situation.
I have generated apparmor rpm following the mentioned guides, I have copy the package in /opt/Xilinx/petalinux-2016.2/components/package-repo/rpm/cortexa9hf_vfp_neon folder, but I can't see it in menuconfig for rootfs.
Clearly some extra steps are missing in the guide
     -> devel
         -> python
              -> python
BRs,
