Add "make" command to Petalinux
Hi, I would like to have the "make" Linux command in my Petalinux.
Can anyone tell me how to add this command to Petalinux?
Thanks in advance
And how can I include the whole toolchain ("gcc") ?
Try Filesystem Packages -> misc -> packagegroup-core-buildessential
(and you'll likely also want packagegroup-core-buildessential-dev in the same place)
You can enable it by running: petalinux-config -c rootfs
In the resulting menu, select Filesystem Packages --> devel --> make.
Note this will only give you the "make" executable. It does not include a whole toolchain (no "gcc").
You can also refer to UG1144.
Hi @rfs613,
Thanks in advance.
why do you think I need buildessential-dev ?
I read somewhere not to select the packages ending with -dev or -dbg
The buildessential package is a shortcut which enables a number of individual packages all related to compiling C/C++ code on the target. Have a look at packagegroup-core-buildessential.bb under layers/core/meta/recipes-core/packagegroups.
Regarding the -dev and -dbg packages: in most cases the advice to not select them is correct - they are large and are not needed by most users. However if you want to compile software on the target, you will probably need header files for libraries that you are linking. The -dev packages contain these headers. As an example, packagegroup-core-buildessential.bb includes libstdc++ and also libstdc++-dev.
The -dbg packages are not needed on the target. They provide debugging info (symbol tables etc) since the target executables are normally stripped of all such unnecessary info. When you compile on the target, you can decide to include debug symbols (compile with -g flag) and whether to strip the resulting executables.
