sigvarth
Adding NTP deamon to petalinux
Any suggestions on how to add NTP deamon to petalinux, I've tried to add the bitbake recipe from here https://layers.openembedded.org/layerindex/recipe/2299/
but it doesn't show up in petalinux-config -c rootfs or kernel. I don't get what I'm doing wrong. Like it looks like the kernel has ntp support from https://github.com/Xilinx/linux-xlnx/blob/master/kernel/time/ntp.c
Tags (3)
aravindb
Please follow below steps to add ntp as a part of your rootfs.
vim project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
add below line
IMAGE_INSTALL_append = " ntp"
user packages --> [*] ntp
petalinux-build
Thanks & regards
Aravind
aravindb
add below line
petalinux-build
Thanks & regards
Aravind
sigvarth
Thank you so much. This worked and NTP deamon is now available in petalinux :)
shustik
Than you very much for your answer!
But I can't understand 2 moments:
1. I would like to use ntpq, but I don't get it together with ntpd. Is it possible to correct it?
2. I can't change server list in /etc/ntp.conf. I created my config file in rootfs/etc/ntp.conf (SD card), but when petalinux starts, I see default configuration at /etc/ntp.conf. What to do?
cbureriu
in Petalinux 2020 it is a little different. You need to edit the file:
<project_name>/project-spec/meta-user/conf
adding the line(s):
CONFIG_ntp
(or CONFIG_<whatever-package>)
then the package to be enabled should show up in:
petalinux-config -c rootfs -> user apps
WilliamMarchant
Could you explain the "user packages --> [*] ntp" step, please?
vanmierlo
Mentor
Mentor
Did you type the following?
WilliamMarchant
Thank you!  That makes sense now.
My board now boots and sets the correct date and an approximate time.  It's about 8 minutes slow.  I waited more than five minutes but the daemon doesn't appear to be slewing the clock.  I assume the /etc/ntp.conf file needs to be updated.
After some searching I was able to edit ~/petalinux/pltools/components/yocto/source/aarch64/layers/meta-networking/recipes-support/ntp/ntp/ntp.conf and, after a petalinux-build and petalinux-package cycle, that edited ntp.conf showed up in the booted system at /etc/ntp.conf.  The system successfully updated its time after the five minute NTP cycle.  So I think I'm past this hurdle.  Thanks for the help!
