Adding Qualcomm Atheros (ath10) support to petalinux
I am trying to interface a wifi module based on Qualcomm chip set (ath-10). I am working on a custom embedded board which is powered by Zynq Ultrascale SoC and the board is connected through a pcie connector on board. I enabled the ps-pcie module in vivado PCW wizard and made the pcie port as a root port.
I also enabled NWL-pcie driver in the kernel and also the other required components
Networking support -> Wireless, enable cfg80211,Generic IEEE 802.11 Networking Stack (MAC80211).
Device Drivers -> Network device support -> Ethernet driver support->Atheros Devices.
Device Drivers -> Network device support -> Wireless LAN -> Atheros/Qualcomm devices and I am compiled as modules both Atheros 802.11ac wireless card support and atheros ath10k pcie support
and I have the two kernel modules ath10k_core.ko and ath10k_pci.ko present at /lib/modules/4.9.0/kernel/drivers/net/wireless/ath/ath10k.
However I cannot load them modprobe says the requested module is not found at /lib/modules/4.9.0/ and insmod returns unresolved symbols error.
Are there any other dependencies?
nwl-pcie is not finding the device and on bootup it always says pcie link is down. Doing an lspci returns this
00:00.0 Non-VGA unclassified device: Xilinx Corporation Device d011
So, Is there any device tree binding necessary for making qualcomm chipsets enumerate?
Re: Adding Qualcomm Atheros (ath10) support to petalinux
Did you end up ever figuring this out?  I found this answer and wondered if it could help.  I wonder if there is something needed to be done at the petalinux build phase?
https://forums.xilinx.com/t5/Embedded-Linux/Adding-packages-to-PetaLinux/td-p/782849
I did figure it out quite a long time ago. I did my own hacks to make the pcie device enumarate and work as intended. My problem was multi pronged not just related to loading the kernel modules.
Was it an issue due to Petalinux?  I'm looking at throwing down an ath10 device but after seeing your thread here I'm not sure I want to.  I have to avoid as much software dev time as possible.
Do you think later linux kernels would have cleared up the driver issue?
If you can describe your problem briefly. I can try to help.
I had my issue from fsbl and also xilinx kernel. Had to add some hooks to fsbl and had to add a few lines of code to kernel source in order to overcome firmware loading issue.
Thanks for all the replies, by the way!
I haven't built anything yet.  I'm the hardware designer trying to make it easy for the software developers by using hardware that is supported with drivers already.  I have narrowed my selection to ath9k and ath10k supported chips.  I'd prefer to use the ath10k supported hardware so I can use 5 GHz.
Would you have any suggestions?  We're using custom hardware wtih zynq ultrascale+.
Thanks again!
ath10k devices and their drivers are perfectly supported by petalinux. I used them in 2017.4, 2018.1 and also 2018.3 versions of petalinux.
Thanks!
