Adding analog devices AXI drivers to petalinux BSP
Analog devices has some ADC drivers in the 3.15 linux kernel that are not available in the linux 3.14 kernel. They are here at:
https://github.com/analogdevicesinc/linux/tree/xcomm_zynq/drivers/iio/adc
I would like to compile some of the new drivers as modules so I can modprobe them into linux. Is there a guide on how to do that?
Re: Adding analog devices AXI drivers to petalinux BSP
It wasn't any problem with the build system. The solution was to change my makefile from this:
obj-$(CONFIG_CF_AXI_ADC) += cf_axi_adc.o ad9467.o ad9361.o admc_adc.o admc_speed.o admc_ctrl.o ad_adc.o
cf_axi_adc-y := cf_axi_adc_core.o cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
to this:
obj-m := ad9467.o ad9361.o admc_adc.o admc_speed.o admc_ctrl.o ad_adc.o
ad9467-y := cf_axi_adc_core.o cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
ad9361-y := cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
admc_adc-y := cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
admc_speed-y := cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
admc_ctrl-y := cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
ad_adc-y := cf_axi_adc_ring.o cf_axi_adc_ring_stream.o
Did you try enabling the driver using petalinux-config -kernel and by selecting industrial I/O?
Achutha
I did enable the iio in the menuconfig.
In the 3.15 kernel from the AD github, there are additional .c and .h files for the ring buffer (linux_src_root/drivers/iio/adc/) and things that are not in the 3.14 xilinx kernel. If I add them to the makefile, the kernel builds, but it does not match the (supposedly built) drivers with the device tree file.
The modules I added are supposedly loaded:
root@Avnet-Digilent-ZedBoard-2014_2:/lib/modules/3.14.2-xilinx# cat modules.builtin | grep adc
kernel/drivers/iio/adc/cf_axi_adc.ko
kernel/drivers/iio/adc/ad9467.ko
kernel/drivers/iio/adc/ad9361.ko
kernel/drivers/iio/adc/admc_adc.ko
kernel/drivers/iio/adc/ad_adc.ko
kernel/drivers/iio/adc/xilinx-xadc.ko
From config.gz:
# Analog to digital converters
CONFIG_CF_AXI_ADC=y
# CONFIG_AD7266 is not set
CONFIG_XILINX_XADC=y
When I try to load the drver with modprobe, it won't load:
root@Avnet-Digilent-ZedBoard-2014_2:/lib/modules/3.14.2-xilinx# modprobe cf_axi_adc
modprobe: module cf_axi_adc not found in modules.dep
root@Avnet-Digilent-ZedBoard-2014_2:/lib/modules/3.14.2-xilinx# modprobe cf_axi_adc.ko
modprobe: module cf_axi_adc.ko not found in modules.dep
I think I am missing something, but I am not sure what.
I believe I know the nature of the problem. Petalinux is building the modules as .o files as it should, and adding the files to the modules.builtin list as it should.
Petalinux is NOT sending the new AD driver .o files to the kbuild system to add them to the data structure that has all the info about the builtin modules (or gets added to the .o file to make a .ko file).
Basically, petalinux is compiling the .c code into the kernel but it is not using the driver build system so the kernel knows they are there. How do I tell petalinux to finish the kbuild process?
to this:
Nick,
Would you mind posting the entire Makefile and a list of what files need to be where for this to work? I am trying to do the same for the AD9671. I am a noob when it comes to building drivers.
-Andrew
