ykota
Adding libs to Petalinux GDB
Hi All,
I am using petalinux on Microzed board which has a zynq SOC. I have a lot of apps and libs that we custom developed for our board. The apps use libs to perform tasks.
Example: components/apps/myApp uses components/apps/myLib
When I want to debug this on the target using gdb, I perform the following steps,
Please Note: Target is connected to host in a private network with IP 192.168.X.X. Host is running a Linux OS
On Target:
cd /bin
gdbserver host:1534 myApp
On Host:
petalinux-util --gdb myApp
target remote 192.168.X.X:1534
With this I can only debug myApp, I cannot debug myLib which is dynamically linked in myApp.
Warning in GDB I get is:
(gdb) target remote 192.168.X.X:1534
Remote debugging using 192.168.X.X:1534
warning: Unable to find dynamic linker breakpoint function.
GDB will be unable to debug shared library initializers
and track explicitly loaded dynamic code.
0xb6fd7ac0 in ?? ()
(gdb)
Has anyone got this to work? Any pointers on how to get this to work??
rfs613
You'll need to have, on your host machine, a version of the library with debug symbols in it (the version on the target can be stripped). Then gdb needs a bit of help to locate the library, typically using the command: set solib-search-path
For more details, you can google the warning message, this is a fairly common question. See for example https://www.fayewilliams.com/2013/01/31/gdb-unable-to-find-dynamic-linker-breakpoint-function/
