Observer david.perlaza
Adding pre-compiled libraries to Petalinux rootfs
I'm trying to add pre-compiled libraries (OpenCV to be more specific) to my Petalinux root file system. I have tested the libraries by coping them to an SD card and setting the environment variable LD_LIBRARY_PATH accordingly, and they work correctly. The problem I am facing is that the documentation for Petalinux does not provide a procedure for this. I have found this AR (http://www.xilinx.com/support/answers/55976.htm); however, the procedure seems to be out of date. I have built my linux system successfully but it does not include the OpenCV libraries.
Any advice would be much appreciated. The version of Petalinux I'm using is 2014.2
David
Re: Adding pre-compiled libraries to Petalinux rootfs
Hi John (and those who may be interested),
The issue has been solved by editing the makefile as follows:
ifndef PETALINUX
$(error "Error: PETALINUX environment variable not set.  Change to the root of your PetaLinux install, and source the settings.sh file")
endif
include libs.common.mk
LIB_DIR=lib
# Add any other object files to this list below
all: build install
.PHONY: build
build:
#Skip Building Libraries. (Already precompiled for ARM platform)
install:
	# Install libraries template
	mkdir -p "$(TARGETDIR)/lib/fonts"
	find $(LIB_DIR)/ -maxdepth 1 -name "*.*" -print0 | xargs -0 cp -pP -r -t "$(TARGETDIR)/lib/"
clean:
	# No Clean operation for pre-built binaries.
David
Hi David,
I can't say I've used this feature, but petalinux-create -t libs is the way they intend you to do this. The help, petalinux-create ?, sort of tells a bit but it's pretty sparse.
I just gave it a quick test and it does create the lib in components/libs/<name> and there's a makefile that looks like a good start. It's really just copying the libs and header files to the root file system I believe.
John
Hi John,
Yes, I have already tried "petalinux-create -t libs -n <name> -s <path to libraries>/lib" and have modified the makefile in a similar way to what is shown in AR# 55976. The libraries are copied to the following folder <root of petalinux project>/build/linux/rootfs/stage/lib, but not to the actual rootfs of my linux system.
Do you have any advice on how to modify the makefile to get the libraries copied to the rootfs?
David
ifndef PETALINUX
endif
LIB_DIR=lib
all: build install
.PHONY: build
build:
install:
clean:
David
gf
thanks
shweta
space appplication center
ahmedabad
David,
I'm trying to make the same thing - build patalinux with opencv libs.
I have added opencv libs (from SDK) to petalinux (petalinux-create -t libs), enable it in rootfs and edit Makefile to copy them into /usr/local/lib/opencv (to add this path to LD_LIBRARY_PATH at runtime).
But when I invoke petalinux-build - I got error.
As far as I understand error is about size of rootfs - opencv libs are to ig to fit in ramfs (rootfs is INITRAMFS).
When I change INITRAMFS to something else - than petalinux-build is ok but petalinux-boot --qemu is not - it can not load rootfs.
How you configure you rootfs to let opencv fit into it?
Or you have made separate image with opencv? Than how you prepare it and mount runtime?
Hi Oleg,
I am not familiar with QEMU; however, I think you are experiencing the same problem I had some time ago. The problem is that the kernel image grows to some 25 MB when OpenCV is added to the rootfs. Then, when the second-stage bootloader decompresses the kernel image, it runs out of memory and the image gets overwritten.
I solved the problem by following fanat9's advice here. Instead of 64 MB, I used 32 MB (0x2000000).
Please note that if you add OpenCV to your PetaLinux project, you won't need to add the libraries to the environment variable LD_LIBRARY_PATH at runtime. This is only required when the libraries are not part of the rootfs image, e.g. when the libraries are stored in the SD card.
Cheers,
David
> "... by editing the Makefile"
Which Makefile??? in the petalinux build area there are 590 of them. (not making this number up, I counted them) This area is still poorly documented. Please help.
