Alternate compile flags (in recipes) in petalinux?
I'm using 2017.3 on zcu102.
I'd like to be able to build a "production" bootable petalinux image, and also a "debug" petalinux image and have them coexist on my build/compile environment at the same time (preferrably without copying and renaming files manually)
I'm thinking I like the way bitbake allows building different recipes, or the way other build tools like visual studio keep Debug and Release executables around simultaneously.
Alternately, maybe I should switch from petalinux to bitbake?  When I first started developing, I couldn't get bitbake to work (but I was using 2017.2, where petaliunux didn't work, either).  When I switched to 2017.3 petalinux, things started working for me, and I haven't gone back to bitbake.
Voyager
Voyager
Re: Alternate compile flags (in recipes) in petalinux?
Write different image recipes for production and debug.
If they are  petalinux-production.bb for production and petalinux-debug.bb for debug,
you can use petalinux-build -c petalinux-production or petalinux-build -c petalinux-debug
The recipes should be like petalinux-user-image.bb
You can find the generated image files under build/temp/deploy/images/plnx-zynqmp
Hi @aaron_b1,
In recipes you can create dev and dbg packages. Something like this
FILES_${PN}-dbg = "\
    ${bindir}/.debug \
    ${sbindir}/.debug \
    ${libdir}/${PN}/.debug \
Then in petalinuxbsp.conf you can control enabling or disabling debug packages using EXTRA_IMAGE_FEATURES variable.
Sandeep
