Application Auto Run at Startup can't petalinux-build
I follow the ug1144 Application Auto Run at Startup at pages 68,69. But when petalinux-build,it shows: INFO: bitbake petalinux-user-image ERROR: ParseError at /home/liwenz/alinx/cnc978/project-spec/meta-user/recipes-apps/udpc-init/udpc-init.bb:23: unparsed line: ' FILES_${PN} += "${sysconfdir}/*"' I don't understand the line and only follow the ug1144. My files is as: # # This file is the udpc-init recipe. # SUMMARY = "Simple udpc-init application" SECTION = "PETALINUX/apps" LICENSE = "MIT" LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302" SRC_URI = "file://udpc-init \ " S = "${WORKDIR}" FILESEXTRAPATHS_prepend := "${THISDIR}/files:" inherit update-rc.d INITSCRIPT_NAME = "udpc-init" INITSCRIPT_PARAMS = "start 99 S ." do_install() { install -d ${D}${sysconfdir}/init.d install -m 0755 ${S}/udpc-init ${D}${sysconfdir}/init.d/udpc-init } FILES_${PN} += "${sysconfdir}/*" Could you give me any advice?
Re: Application Auto Run at Startup can't petalinux-build
HI @liwenz
I hope may be the buils issues due to spaces. Please follow below steps & build It should work.
1. petalinux-create -t apps --template install -n myapp-init --enable
2. vim project-spec/meta-user/recipes-apps/myapp-init/myapp-init.bb
#thiss file is the myapp-init recipe.
SUMMARY = "Simple myapp-init application"
LICENSE = "MIT"
SRC_URI = "file://myapp-init \
S = "${WORKDIR}"
inherit update-rc.d
INITSCRIPT_NAME = "myapp-init"
do_install() {
install -m 0755 ${S}/myapp-init ${D}${sysconfdir}/init.d/myapp-init
3. Modify your script (project-spec/meta-user/recipes-apps/myapp-init/files/myapp-init)according to your requirements and build it.
Thanks & regards
Aravind
Thanks & Regards
Aravind
HI @liwenz
LICENSE = "MIT"
S = "${WORKDIR}"
inherit update-rc.d
do_install() {
Thanks & regards
Aravind
Thanks & Regards
Aravind
yes, maybe space or other thing. After I copied sth from website, it works well now.
Thanks!
