Auto insert modules Petalinux 2018.3
Hi, all!
1. I tried add line in Make file of my_module:
$(TARGETINST) -d -a "my_module" /etc/modules
but in rootsf no folder /etc/modules
2. I tried add line KERNEL_MODULE_AUTOLOAD += "my_module" in distribution configuration <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
But I did not succeed.
Does anyone else know how to solve this problem?
Tags (2)
Re: Auto insert modules Petalinux 2018.3
I manualy create /etc/modules file with
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
my_module
and module was loaded successfully.
my_module
