Avnet Ultrazed-EV SOM: Red led when boot fails
Hi Xilinx,
 I was wondering if someone could explain the mechanism of the red LED3:  PS_ERROR_OUT on the Avnet Ultrazed-EV SOM board.
I know the label says something like : there is an error on the PS side :-) but I like to comprehend what is causing the led to light up.
Because it is strange it waits 8 seconds before it get activated so I have the feeling this questions answer might pop up in the future again with our future designs.
The ZCU 102 has a sililar LED ( PS_ERR_OUT ) but starts to light up after 1 second.
Thanks for your answer,
Deville
Re: Avnet Ultrazed-EV SOM: Red led when boot fails
Hi @xilinxacct
Thanks for your help and the link. This does not quite answer my question, but I know the question was a bit vague as I did not really have a problem.
Because it was an Avnet board I also openened a forum post there.
https://www.element14.com/community/message/271720/l/avnet-ultrazed-ev-red-led-when-boot-fails#271720
Kind regards. Deville
@deville
Does this address your question?
https://forums.xilinx.com/t5/Evaluation-Boards/ZCU102-board-PS-error-out-led/m-p/882733#M18899
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed. :-)
Hi @xilinxacct
