mfonseca
BFD 2.16 assertion fail when cross compilng certain pkgs (e.g. libpam) with microblaze toolchain
Has anyone come across this problem when cross compiling with the microblaze toolchain?  I've noticed it when compilng a number of packages, (eg libpam, zlib, etc.).
Heres some error output:
microblaze-unknown-linux-gnu-gcc -I../../../libpam/include -I../../../libpamc/include -I./.. -fpie -Os -W -Wall -Wbad-function-cast -Wcast-align -Wcast-qual -Wmissing-declarations -Wmissing-prototypes -Wpointer-arith -Wreturn-type -Wstrict-prototypes -Wwrite-strings -Winline -Wshadow -pie -Wl,-O1 -Wl,--as-needed -Wl,-O1 -o .libs/upperLOWER upperLOWER.o  -L/home/mfonseca/views/all/TOOLS/Linux_Toolchains/fortress/build/work/microblaze-rootfs/prod/flex-2.5.35 -L/home/mfonseca/views/all/TOOLS/Linux_Toolchains/fortress/build/work/microblaze-rootfs/prod/Linux-PAM-0.99.9.0/libpam /home/mfonseca/views/all/TOOLS/Linux_Toolchains/fortress/build/work/microblaze-rootfs/prod/Linux-PAM-0.99.9.0/libpam/.libs/libpam.so -ldl
/tools/gcc-4.1.2-glibc-2.3.6/microblaze.Apr.30.1272651460/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: BFD 2.16 assertion fail ../../binutils-2.16/bfd/elf32-microblaze.c:1095
/tools/gcc-4.1.2-glibc-2.3.6/microblaze.Apr.30.1272651460/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: upperLOWER.o: probably compiled without -fPIC?
/tools/gcc-4.1.2-glibc-2.3.6/microblaze.Apr.30.1272651460/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: final link failed: Bad value
collect2: ld returned 1 exit status
Marco
jpl@xiphos.ca
I've not had this problem with building zlib from buildroot.  I have not tried this with pam.
I've attached the build log for the zlib part of buildroot.  What are the configuration options and source for pam?  Perhaps I could try to replicate your error.
Joshua
mfonseca
Can you try zlib again with -Os optimization?
(specificly this is what I am doing)
CC=microblaze-unknown-linux-gnu-gcc ./configure --prefix=/tmp/foo --shared
make CFLAGS="-Os"
I noticed with -O2 it works, but -Os it doesn't.
jpl@xiphos.ca
Hmm, I don't know if I trust anything other than -O2.  I'm working within a system that has 100's of megabytes of RAM, so there isn't any advantage to using -Os.  What type of size improvement do you get when you build with Os?  What are your platform constraints?
Joshua
mfonseca
I think I spoke to soon.  Another look shows that CFLAGS is changing more then optimzation, its also removing -fpic from the compile line.  I will double check these with the problems I'm having with other utilities as well and post back.
It is strage that other toolchains didn't error out with this.
Marco
mfonseca
So I went ahead and tried libpam again, this time removing all of my input, be it flags or patches:
wget ftp://ftp.kernel.org/pub/linux/libs/pam/library/Linux-PAM-1.1.1.tar.bz2
tar xf Linux-PAM-1.1.1.tar.bz2
cd Linux-PAM-1.1.1
./configure --build=i686-pc-linux-gnu --host=microblaze-unknown-linux-gnu
make
... bla ...
libtool: link: microblaze-unknown-linux-gnu-gcc -I../../../libpam/include -I../../../libpamc/include -I./.. -fpie -g -O2 -W -Wall -Wbad-function-cast -Wcast-align -Wcast-qual -Wmissing-declarations -Wmissing-prototypes -Wpointer-arith -Wreturn-type -Wstrict-prototypes -Wwrite-strings -Winline -Wshadow -pie -Wl,--as-needed -Wl,-O1 -o .libs/upperLOWER upperLOWER.o  -L/home/mfonseca/slks/Linux-PAM-1.1.1/libpam /home/mfonseca/slks/Linux-PAM-1.1.1/libpam/.libs/libpam.so -ldl -lcrypt -Wl,-rpath -Wl,/lib64
/tools/microblaze-unknown-linux-gnu/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: BFD 2.16 assertion fail /home/ddeboni/src/Linux/crosstool/crosstool-ng-1.4.1/targets/src/binutils-2.16/bfd/elf32-microblaze.c:1095
/tools/microblaze-unknown-linux-gnu/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: upperLOWER.o: probably compiled without -fPIC?
/tools/microblaze-unknown-linux-gnu/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: final link failed: Bad value
Still the same problem.  *Maybe(?)* it can be made to work with enough tweaking to flags, but I would think it should be able to compile without the toolchain asserting.
Think you could verfity this?
Marco
jpl@xiphos.ca
I'll give it a shot when I'm at my build host, but I just want to confirm your build environment.  What linux installation are you running? If it is 64-bit, I won't be able to offer you a full replication since I'm still hanging out in a 32-bit universe.  I also run somewhat of a Fedora shop.
Joshua
jpl@xiphos.ca
Yeah, I get exactly the same output.
libtool: link: microblaze-unknown-linux-gnu-gcc -I../../../libpam/include -I../../../libpamc/include -I./.. -fpie -g -O2 -W -Wall -Wbad-function-cast -Wcast-align -Wcast-qual -Wmissing-declarations -Wmissing-prototypes -Wpointer-arith -Wreturn-type -Wstrict-prototypes -Wwrite-strings -Winline -Wshadow -pie -Wl,--as-needed -Wl,-O1 -o .libs/upperLOWER upperLOWER.o  -L/home/jpl/dev/exnet/Q6/xilinx/microblaze_v1.0/xbr-q6-svn/build/Linux-PAM-1.1.1/libpam /home/jpl/dev/exnet/Q6/xilinx/microblaze_v1.0/xbr-q6-svn/build/Linux-PAM-1.1.1/libpam/.libs/libpam.so -ldl -lcrypt
/home/jpl/dev/exnet/Q6/xilinx/microblaze_v1.0/microblaze-unknown-linux-gnu/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: BFD 2.16 assertion fail /home/ddeboni/src/Linux/crosstool/crosstool-ng-1.4.1/targets/src/binutils-2.16/bfd/elf32-microblaze.c:1095
/home/jpl/dev/exnet/Q6/xilinx/microblaze_v1.0/microblaze-unknown-linux-gnu/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: upperLOWER.o: probably compiled without -fPIC?
/home/jpl/dev/exnet/Q6/xilinx/microblaze_v1.0/microblaze-unknown-linux-gnu/bin/../lib/gcc/microblaze-unknown-linux-gnu/4.1.2/../../../../microblaze-unknown-linux-gnu/bin/ld: final link failed: Bad value
 I tried a couple of quick different configures with adding --disable-pie or --with-gnu-ld, and it failed with some unresolved symbol (yywrap) or with the same error, respectively.
Sorry it wasn't better news.
Joshua
mfonseca
For those who might benefit from this:
The problem with building pam with the xilinx toolchain, is that it doesn't support the -pie gcc flag.  If you configure pam with --disable-pie , it will get around the BFD assertions.  It seems like most of the BFD assertion problems have to do with pic.
linnj
Thanks for that update, that may help others.
Anonymous
Not applicable
I got assertion failures  when compiling the linux kernel.  I checked the makefile and saw:
ifdef CONFIG_DEBUG_INFO
KBUILD_CFLAGS   += -g
KBUILD_AFLAGS   += -gdwarf-2
endif
ifdef
CONFIG_DEBUG_INFO
KBUILD_CFLAGS   += -gKBUILD_AFLAGS   += -gdwarf-2
endif
So I disabled CONFIG_DEBUG_INFO in the .config and the assertion failures went away.  PROBLEM SOLVED!!
Ideally I'd play around with the flags to get rid of the error so the debug info works but if anyone needs a quick fix perhaps this will be useful info.
Billy.
patoh
Something additional to be aware of, which I came across while build libpcap with the Xilinx MicroBlaze LDK.
You may need to verify if the -fpic inclusion is in upper or lowercase.
While building with -fpic did not work and produced the same BFD assertion failure. Building with -fPIC resolved the issue.
So for sharing purposes the configure command line used to build libpcap was as follows:
tar xvf libpcap-1.1.1.tar
cd libpcap-1.1.1
mkdir build
cd build
../configure --host=microblaze-unknown-linux-gnu --with-pcap=linux ac_cv_linux_vers=2
After which I hand editing the CCOPT to replace:
CCOPT = -O2 -fpic
with
CCOPT = -O2 -fPIC
Then ran make, and make install.
Hope this saves someone else some time.
