Visitor ambe
BUS Error is occured when get data from mmap() address
I'm developping peripheral interfaces on PetaLinux with ZynqMPSoC Architecture.
I try porting from standalone application code to petalinux application using mmap().
Then, Getting virtual address via mmap(), I try to access address considering offset.
But BUS error is occured.
My code is below:
#define BASE_ADDR_MASK 0xFFFF0000
static INLINE u32 Xil_In32(UINTPTR Addr)
	printf("Xil_In32 start.\n");
	UINT64 *vptr = NULL;
	static int fd;
	unsigned int page_size = getpagesize();
	UINTPTR base = Addr&BASE_ADDR_MASK;
    if ((fd = open(DEVMEM_PATH, O_RDWR | O_SYNC)) == -1) {
    	perror("open error");
    	return 0x0;
    vptr = (UINT64 *)mmap(NULL, page_size, PROT_READ|PROT_WRITE, MAP_SHARED,
        						fd, base);
    if (*vptr == -1){
	    	perror("mmap error");
	    	return 0x0;
    close(fd);
    printf("Xil_In32 end.\n");
    UINT32 ret =  0;
    ret = (UINT32)*(vptr + (Addr - base));
    munmap(vptr, page_size);
    return ret;
//	return *(volatile u32 *) Addr;
Visitor ambe
Re: BUS Error is occured when get data from mmap() address
Thank you for replying.
I tried the source code that is shown at wiki page.
Then, it is necessary for using mmap that add below code to target device in the devicetree(system-user.dtsi).
status = "disabled";
This setting works and BUS error is stopped.
HI @ambe
Please refer below link for mmap() usage.
:https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842018/Linux+User+Mode+Pseudo+Driver
Thanks & regards
Aravind
Visitor ambe
Observer magonmonkey
Hi ambe,
We're now countering a similar problem. We try to port working standalone code to petalinux application. We access the AXI_DMA using mmap() but it will cause bus error. The AXI_DMA is in our pl.dtsi and our system-user.dtsi is empty.
Could you please elaborate on what changes needed to be made in the device tree file, what does the status = "disabled"; mean? Or can you please share your working .dtsi files? Any help would be greatly appreciated!
Visitor ambe
My case is I2C.
I couldnt find suitable device driver, then I tried to direct access to the target I2C device.
And my system-user.dtsi source was below:
/include/ "system-conf.dtsi"
   memory {
       device_type = "memory";
       reg = <0x0 0x0 0x0 0x80000000>, <0x0 0xFF020000 0x0 0x40000>, <0x00000008 0x00000000 0x0 0x80000000>;
   reserved-memory {
       #size-cells = <2>;
       #address-cells = <2>;
       ranges;
       reserved {
           reg = <0x0 0xFF020000 0x0 0x40000>;
&i2c0 {
disabling I2C device and adding reserved-memory for I2C device address.
But finally, I found a suitable I2C device driver for my product used.
We resolve our problem by disabling our axi-dma in the device tree.
Thanks a lot!
