Observer ralphkw1
Baffled with Petalinux 17.2 build process
I would really like to have the ability to do simple compiles either command line or eclipse for development purposes. I know I will need to do the proper image creation using petalinx-build when testing my changes. But I do a lot of incremental builds while developing and yocto is just too darn slow. So I did a full build which was successful, and I looked at the log.do_compile. It has two lines as follows.
arm-xilinx-linux-gnueabi-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a9 --sysroot=/opt/zc706/build/tmp/sysroots/plnx_arm -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/opt/zc706/build/tmp/work/cortexa9hf-neon-xilinx-linux-gnueabi/system-server/1.0-r0=/usr/src/debug/system-server/1.0-r0 -fdebug-prefix-map=/opt/zc706/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/opt/zc706/build/tmp/sysroots/plnx_arm= -fvisibility-inlines-hidden -std=gnu++11 -c -o system_server.o system_server.cpp
arm-xilinx-linux-gnueabi-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a9 --sysroot=/opt/zc706/build/tmp/sysroots/plnx_arm -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o system-server system_server.o -lrt -lpthread -lpmq
So in the same build window I tried to execute those two lines exactly as the log shows. The compile works, but the link gives me these errors as follows. Mind you that the petalinux-build with the exact same files (the result in the log file) works fine. So what gives? If it works with the petalinux build, should I not be able to execute the logged compile and link and get the same result? Yocto is a never ending cluster puck it seems...
rkwilliamson@ubuntu:/opt/zc706/project-spec/meta-user/recipes-apps/system-server/files$ arm-xilinx-linux-gnueabi-g++ -march=armv7-a -marm -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a9 --sysroot=/opt/zc706/build/tmp/sysroots/plnx_arm -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o system-server system_server.o -lrt -lpthread -lpmq
/opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/../../../../arm-xilinx-linux-gnueabi/bin/ld: error: system-server uses VFP register arguments, /opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/crtbegin.o does not
/opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/../../../../arm-xilinx-linux-gnueabi/bin/ld: failed to merge target specific data of file /opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/crtbegin.o
/opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/../../../../arm-xilinx-linux-gnueabi/bin/ld: error: system-server uses VFP register arguments, /opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/crtend.o does not
/opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/../../../../arm-xilinx-linux-gnueabi/bin/ld: failed to merge target specific data of file /opt/Xilinx/SDK/2017.2/gnu/arm/lin/bin/../lib/gcc/arm-xilinx-linux-gnueabi/4.9.2/crtend.o
system_server.o: In function `system_server::init()':
/opt/zc706/project-spec/meta-user/recipes-apps/system-server/files/system_server.cpp:314: undefined reference to `system_command(SYSTEM_COMMAND_PARAMETERS, SYSTEM_COMMAND_PARAMETERS, char const*)'
system_server.o: In function `system_server::post_init()':
/opt/zc706/project-spec/meta-user/recipes-apps/system-server/files/system_server.cpp:397: undefined reference to `system_command(SYSTEM_COMMAND_PARAMETERS, SYSTEM_COMMAND_PARAMETERS, char const*)'
/opt/zc706/project-spec/meta-user/recipes-apps/system-server/files/system_server.cpp:398: undefined reference to `system_command(SYSTEM_COMMAND_PARAMETERS, SYSTEM_COMMAND_PARAMETERS, char const*)'
system_server.o: In function `system_server::shutdown_with_log(int, int, int, std::string)':
/opt/zc706/project-spec/meta-user/recipes-apps/system-server/files/system_server.cpp:890: undefined reference to `system_command(SYSTEM_COMMAND_PARAMETERS, SYSTEM_COMMAND_PARAMETERS, char const*)'
collect2: error: ld returned 1 exit status
Voyager
Voyager
Re: Baffled with Petalinux 17.2 build process
Hey @ralphkw1,
Looks to me like a problem with different environments, more specifically the PATH environment variable could differ between the two invocations resulting in different compiler/linker being executed with different defaults.
Probably the best approach is to output the environment in the script and compare it to your build window environment.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Voyager
Voyager
Hey @ralphkw1,
Hope this helps,
Herbert
Observer ralphkw1
Thanks 'hpoetzl' for the tip. It was not the PATH but some other environment variable. I added 'printenv' to the makefile and during the yocto build, it saved the environment to log.do_compile. I then imported this environment to bash and did the compile. It worked. So I am not sure which variable(s) are necessary, but that was the solution.
Voyager
Voyager
You're welcome!
All the best,
Herbert
Have you tried building the recipe with -c devshell? I haven't tried this but saw it when reading through the docs. Is supposed to put you in a shell in the yocto build environment that is fully initialized.
jeff
