Visitor daromart
Bare metal hello world on ZYNQ through u-boot
Hi all,
I have a ZYNQ7000-based board (Zedboard) running u-boot + Linux without problems, and I would like to run a simple bare metal hello world from u-boot (that is, instead of loading Linux zimage, I want to load a simple bare metal binary).
Following Xilinx tutorials, I managed to build a bare metal hello world (the one provided by Xilinx SDK), run it on the board through the ISE/JTAG link and get a "hello world" message succesfully.
However, if I try to load the binary through u-boot (using tftp and go) no message is displayed. Could somebody give me a clue?
Thanks a lot,
Dan
Re: Bare metal hello world on ZYNQ through u-boot
I don't know of any reason why it wouldn't work, but we don't test it at this point that I know of anyway.
Can you check the addresses where everything got linked to make sure that there's no overlap with u-boot?
You may need to go ahead and set some breakpoints to debug a bit more. I would be interesting to know if it got to main ok and it's just the print not working.
Visitor daromart
Dear John,
Thank you very much for your answer.
It was just a small mistake of mine. I was trying to load the "hello.elf" file directly instead of converting it to binary form using:
arm-xilinx-linux-gnueabi-objdump -S hello.elf -o hello.bin
(and then loading it with: $tftp 0x100000 hello.bin $go 0x100000)
Now everything is working!!
Sorry for the inconvenience ^^U
Incidentally, I thought I was committing the same error in http://forums.xilinx.com/t5/EDK-and-Platform-Studio/Standalone-Hello-World-on-QEMU-ZYNQ-A9/td-p/259702 (running the hello world through Xilinx QEMU), but unfortunately it still gives me an error [qemu: fatal: Unimplemented cp15 register write (c12, c0, {0, 0})]. Perhaps that error means that QEMU support is still incomplete. But on the other hand, Linux works correctly on QEMU so it is kind of strange that the SDK hello-world application doesn't... hmm
Best regards and thanks a lot for your reply,
Dani
Visitor bhargavmr
Where can I find instructions for running Bare metal hello world in QEMU. I am using ISE 14.5 and arm-xilinx-linux-gnueabi-objdump is not supporting -o option for creating bin file.
Bhargav
Me too... no objdump -o. Don't keep all the secrets to yourself!
Scholar rfs613
Recommend you use objcopy instead of objdump:
arm-xilinx-linux-gnueabi-objcopy -O binary hello.elf hello.bin
That's a capital letter "O", not zero, by the way.
Yes, thanks, I did discover objcopy actually.
Although, if you're working with baremetal, you may want to use arm-xilinx-eabi-objcopy instead.
However, it still wasn't working for me, so I wasn't happy to call it "the solution".
I attempted to load that binary file in U-Boot, and it reported:
Wrong Image Format for bootm command
ERROR: can't get kernel image!
I'm not sure if the boot actions should be slightly different if I'm not actually booting a Linux kernel, but instead a baremetal application.
EDIT: Oh, I see the U-Boot command before was "go" instead of "bootm", so I will try that.
Scholar rfs613
The "go" command should work for you. It just jumps to whatever address you specify.
For reference: "bootm" expects an image wrapped in a header (produced by "mkimage" tool). It also does more than just jump: it massages the commandline arguments into the device tree, and sets up certain registers to pass the devicetree (and possibly ramdisk) to the Linux kernel.
I was successful at booting a baremetal ELF file by loading into the DDR then using the "bootelf" command.
For example, if loading from an SD card, you can use:
fatload mmc 0 0x10000000 <your_file>.elf
bootelf 0x10000000
Note: This was using Petalinux 2017.4
