Blink LEDs in Linux on Zynq through /dev/mem
Hello everyone!
I have Linux booted on my Zynq Mini ITX board.
I've added axi_gpio IP to my design and wrote an .xdc file so that its outputs are assigned to LEDs present on my board. But when I write to axi_gpio's base address through /dev/mem, nothing happens and my LEDs do not flash.
Is there something else I should do before it works?
Re: Blink LEDs in Linux on Zynq through /dev/mem
The first thing I would do is load up a standalone application and verify that you can access the LED's that way. If you can, at least you know your hardware is setup correcty. If that works, then you should be able to use /dev/mem or even the Linux gpio driver. There are many example of touching various HW registers in the PL out there, it's pretty straightforward.
Terry
Terry
Thank you,
I was a bit too fast asking this question. I managed to do this using uio according to this tutorial:
http://fpgacpu.wordpress.com/2013/05/28/how-to-design-and-access-a-memory-mapped-device-part-two/
Visitor nymitr
linux kernel has driver to leds connected to gpio lines.  https://www.kernel.org/doc/Documentation/devicetree/bindings/leds/leds-gpio.txt
Does this require any changes to PL? Can the Linux kernel drive the LEDs on ZC706 with just the PS? Any pointers? Thanks!
I connected my Zynq PS to output pins via axi_gpio. So you have to connect axi_gpio to PS via axi_interconnect core and then make axi_gpio output ports external. You will also have to assign them to hardware LED ports in .xdc. I did it on Zynq Mini ITX board according to this design:
Embedded Standalone OS (Bare-Metal) Reference Design ITX
from this page:
http://zedboard.org/support/design/2056/17
You will also have to make a device tree entry for your axi_gpio leds. It's written how to do that in the tutorial I've posted above.
