04-25-2008 06:28 PM
Hello all,
I am trying to use Bluecat Linux distrubition on Spartan 3E starter kit. But generating libraries make this problem
ERROR:MDT - linux_bc54 () - integer value too large to represent
while executing
"format "0x%08X" $param_value"
("STD_LOGIC_VECTOR*" arm line 6)
invoked from within
"switch -regexp $data_type {
INTEGER {
set param_value [string map {_ ""} $param_value]
STD_LOGIC_VECTOR* {
set param_value [strin..."
(procedure "add_xparam_peripheral" line 22)
invoked from within
"add_xparam_peripheral $xparam_file $periph_string $args"
(procedure "add_xparam_driver" line 52)
invoked from within
"add_xparam_driver $xparam_file $drv"
(procedure "add_xparam_drivers" line 16)
invoked from within
"add_xparam_drivers $drvlist"
(procedure "::sw_linux_bc54_v1_00_a::post_generate" line 22)
invoked from within
"::sw_linux_bc54_v1_00_a::post_generate 52882264"
ERROR:MDT - Error while running "post_generate" for processor microblaze_0...
make: *** [microblaze_0/lib/libxil.a] Error 2
Done!
Apparently is the parameter XPAR for BRAM has a value a long hex value.
I have two question?
1 - Is bluecat can work on spartan3E starter kit? I cannot see any xprarmeters.h in linux tree for microblaze?
2 - Is there any working linux for microblaze under spartan 3e?
Thanks in advance
06-06-2008 05:03 AM
Hello everyone,
I'm also getting this error... What is wrong? Is there any way to fix it?
Waiting for your response.
Thanx for any help.
07-18-2008 08:06 AM
I am also facing the same error.
In order to debug, I added some puts in the scripts.
The integer value that is too large is "0x000002FC000002FC000002FC000002FC000002FC000002FC000002FC000002FC" in my system. Parameter name is C_CTRL_BRAM_INIT_xx
I found out that this value is defined in "__xps/DDR_SDRAM_mpmc_ctrl_path_params.v" and in "hdl/ddr_sdram_wrapper.v" files.
Since these files are automatically generated, I have not tried to modify them.
Can anybody suggest the solution?
Maybe we are missing somthing while configuring the IP's.
Is this someway related to the "mark to initilise BARM" under software projects->default: microblaze_0_bootloop?
