nikeeag
Boot Linux from PL side[ZCU106]
I need help with booting Linux from my ZCU106 from PL side DDR and PS just acts as storage.
Could someone help on this?
Thanks and regards
Nikesh
ritakur
Assuming you have a MIG design for ZCU106, then you just need to select PL DDR as the primary system memory in petalinux-config menu (Subsystem AUTO Hardware Settings -> Memory Settings )
nikeeag
Hi Ritakur,
That would imply that I have to use my own bit file too which has Xilinx MIG design? Is my understanding correct?
Thanks and regards
Nikesh
ritakur
yes, since you want to boot from PL side DDR, you need a soft IP DDRC(MIG) in PL.
Note, U-boot doesn't support high memory, it needs to run from memory (0 to 4GB).
nikeeag
But PL Side DDR is above 4GB, how can I make U-Boot work then?
ritakur
all the U-Boot Drivers should be capable to run in 64 bit mode and able to access and work with high address area covering the full DDR range.
This will be a huge modification, we have internal request but was withdraw.
nikeeag
This is not working just changing to PL DDR as main memory
ritakur
As I mentioned U-boot doesn’t support high address.
I think u-boot will hang if you are using PL DDR as the main memory.
nikeeag
I get your point. However, how abt if i map my PL-DDR to 256MB from A000_0000 to AFFF_FFFF. In that case i should still be able to boot from PL DDR yet keeping my U-BOOT below the high memory?
Could you let me know the steps for this?
Thanks and regards
Nikesh
